How to aim spot lights on driving bar?
Results 1 to 7 of 7
Thread: How to aim spot lights on driving bar?
  1. #1
    Join Date
    Jun 2007
    Location
    Lasalle
    Age
    41
    Posts
    287
    Post Thanks / Like
    Hey xer's!! Just a question for anyone... I just finish mounting my new Cobra lightbar with a 3" headlight ext.(Glen's) It looks good to me but is there any eary way to aim the lights properly? Is it better to tip downward slightly?
    Thanks
  2. #2
    Ghost 26's Avatar
    Ghost 26 is offline Not as old as I feel...
    Wyoming Riders Group
    Join Date
    Feb 2007
    Location
    Rock Springs
    Age
    51
    Posts
    1,442
    Post Thanks / Like
    I don't have the Cobra lights, but I doubt the type matters on this issue. I found that the higher I aimed them, the better they worked (within limits) but that also led to more people getting upset about how bright they were.
    I originally put the bike about 20 feet from a wall, had someone sitting on the bike keeping it upright, and aimed the lights so that the top of the main bright spot from the lights was about 3 inches lower than the middle of the light bodies. This gave me fantastic lighting results, but resulted in many people giving me the "bright lights" flip of their lights, and actually caused one person I was following to yell out the window that my lights were WAY too bright.
    As time went by I slowly lowered the lights until the number of people I annoyed felt reasonable and I could still see well at night. That fine line is in there somewhere, but is probably different for each person.
    While you are working on the lights, you will probably want to adjust your headlight too. Mine came aimed rediculously low. Look on the bottom of the headlight for two small holes leading into the body of the headlight and use a long, thin phillips (I think) screwdriver to adjust it like you would a car headlight - one screw adjusting the left/right and the other adjusting the up/down.
    Keep in mind that if you ride at night with a passenger you will have to fine a happy medium between the two passenger setups, or adjust your rear shocks so that the rear of the bike doesn't drop as much, causing the lights to go into other driver's eyes.
    G26
  3. #3
    Join Date
    Jun 2007
    Location
    Lasalle
    Age
    41
    Posts
    287
    Post Thanks / Like
    Thanks Ghost, will try this.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Jan 2006
    Location
    Roseburg
    Posts
    2,125
    Post Thanks / Like
    I beleave it is 3ft high on the wall and 17ft away, thats to the top of the beam, low beam, rule of thumb, and I put the lights on the light bar, left side just under the low beam, and the right one same height as the beam but over to the right, we have alot of deer around here and I can see eyes up the road ahead of time.
  6. #5
    Bassdude404's Avatar
    Bassdude404 is offline The guitar, not the fish!
    Ohio Riders Group
    Michigan Riders Group
    Indiana Riders Group
    Illinois Riders Group
    Join Date
    Sep 2007
    Location
    Rolling Prairie, Indiana
    Age
    53
    Posts
    33,378
    Post Thanks / Like
    When I adjusted mine (Hondaline), I had my fiancee' sit on the bike, holding it upright, pointed at the garage door....Then I just adjusted them to the same level as the headlight...
  7. #6
    Bono's Avatar
    Bono is offline AIRBORNE
    Oregon Riders Group
    California Riders Group
    Nevada Riders Group
    Join Date
    Jan 2008
    Location
    Sacramento
    Age
    56
    Posts
    5,567
    Post Thanks / Like
    The stealer did mine and they are bright! I love the difference. I get bright lighted all the time, then I give them bright lights! Bright light save lives. Oh crap I started that thing again! I don't need to hear about smart driving saves lives again. Loud pipes and bright lights help you can be seen and heard!
  8. #7
    Charlie D's Avatar
    Charlie D is online now Senior Member
    Washington State Riders Group
    Oregon Riders Group
    Join Date
    Aug 2006
    Location
    seatac, Washington
    Age
    60
    Posts
    18,423
    Post Thanks / Like
    I put 55 watt driving lights on mine and mounted to the turn signal bar (1300 S)
    to aim I just put the jack under the bike and lifted just enough for it to sit level closed the garage door and turned all the lights then I adjusted them a few inches below the headlight beam.
    I have only been flashed 2 times and I light up everything for a block away
Thread Information
Users Browsing this Thread
    1. I want driving lights not light bar
      By engineer685 in forum Honda VTX 1300 Forums
      Last Post: 06-11-2012, 09:25 AM
    2. Fork Mounted Driving Lights...
      By Beastie Boy in forum Honda VTX 1800 Forums
      Last Post: 05-09-2008, 04:46 PM
    3. Driving Lights/Fog Lights
      By lzt0d2 in forum Honda VTX 1300 Forums
      Last Post: 08-17-2007, 09:55 PM
    4. Aiming driving lights
      By Goldsmith in forum General VTX/Motorcycle Topics
      Last Post: 05-09-2007, 02:55 PM
    5. Need some advice on driving lights
      By 911Radioman in forum Honda VTX 1300 Forums
      Last Post: 04-05-2007, 11:03 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
