hard to shift to 1st gear
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: hard to shift to 1st gear
  1. #1
    Join Date
    Jun 2013
    Location
    Provo
    Posts
    29
    Post Thanks / Like
    sometimes when i first get going its hard to get the bike into first gear and then it makes a weird whirling noise its only done this a few times, is this normal or should i be worried?
  2. #2
    Join Date
    May 2011
    Location
    Galion, Ohio
    Posts
    4,394
    Post Thanks / Like
    I have read this before you should grease the linkage first then we can go from there.
  3. #3
    Join Date
    Apr 2013
    Location
    Urbana
    Posts
    29
    Post Thanks / Like
    Not sure about the whirling noise, and when others chine in they may tell you thats the issue. But where are you shift ing to first from? Neutral after staring it up? I believe everyone will tell you that she'll clunck down in to first from anywhere. But if your pulling up to a stop light w/ the clutch in from 4th or 5th and come to a stop it may be nearly impossible to shift down to first. You'll have to let out the clutch slightly w/ slight throttle (w/ no intention of moving) and shift down, repeat until you get to neutral of first.. Best practices are, on decel w/ clutch in shift down to first by the time you stop, Or shift down through your gears and use them to help us low you down.. From 5th I drop to 3rd then 2nd and 1st..
    Again it maybe a bigger issue that has to do w/ the whirling noise, but I hope that helps. It took me a few months to figure out how to use this transmission to its potential. I had started a thread about it and all the convo on there really helped me enjoy the bike so much more!
    Sent from Motorcycle.com Free App
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Jun 2013
    Location
    Provo
    Posts
    29
    Post Thanks / Like
    i was sitting at a stop light and couldnt get it into 1st, so i need to grease the linkage? the bike had only been running a few mins, 80 degrees out 2006 15k miles
  6. #5
    Philscbx's Avatar
    Philscbx is offline Pursuing Perfection
    Minnesota Riders Group
    Join Date
    Jul 2006
    Location
    Mpls Mn
    Posts
    5,859
    Post Thanks / Like
    REMOVE the shifter off the pivot bolt
  7. #6
    Donut's Avatar
    Donut is offline Senior Member
    Michigan Riders Group
    Indiana Riders Group
    Join Date
    Jan 2010
    Location
    Coloma,Michigan
    Age
    68
    Posts
    7,390
    Post Thanks / Like
    Not sure on your discription.
    shift linkage could be gummed up. 3/8"to 3/4" playai the end of the clutch lever.
    The gears are square and sometimes you may need to let the clutch lever out a little then pull back in to help align the gears. even if everything is adjusted properly this can happen.
  8. #7
    Join Date
    Dec 2011
    Location
    Cincinnati
    Posts
    84
    Post Thanks / Like
    If you're at a dead stop, you may need to let the clutch lever out a little bit so the dogs will fall into place. You'll hear it drop into gear.
    This has been true of all my bikes. Shift down to first right before you stop rolling, it won't happen.
  9. #8
    Join Date
    Aug 2011
    Location
    Louisville
    Posts
    282
    Post Thanks / Like
    My bike does that .If I let it slow down more to say 10mph before hitting first it dose not do it . I have quiet pipes so I hear everything. The 750 honda I had did it too.
  10. #9
    Join Date
    Jun 2013
    Location
    Provo
    Posts
    29
    Post Thanks / Like
    ill try letting out the clutch alittle next time it does it, thanks all
  11. #10
    Philscbx's Avatar
    Join Date
    Jul 2006
    Location
    Mpls Mn
    Posts
    5,859
    Post Thanks / Like
    It's a Constant Mesh Transmission -
    There are no gears being engaged -
    Only DOGS on the side of gears
    Nothings changed in 50 years.
Thread Information
Users Browsing this Thread
    1. Question Loud Shift from 1st to 2nd?
      By SKARFCE in forum Honda VTX 1800 Forums
      Last Post: 11-08-2011, 10:22 PM
    2. gear shift
      By buda74 in forum General VTX/Motorcycle Topics
      Last Post: 07-16-2011, 01:38 PM
    3. Motor dies when shift into 1st
      By jvarnell in forum Honda VTX 1300 Forums
      Last Post: 07-13-2010, 10:02 AM
    4. Hard to get in to 1st gear
      By aztec_warrior in forum Honda VTX 1800 Forums
      Last Post: 08-21-2008, 08:48 AM
    5. will not shift into 1st
      By WILD E in forum Honda VTX 1800 Forums
      Last Post: 05-17-2006, 08:12 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
