Question Charging issue
Results 1 to 5 of 5
Thread: Charging issue
  1. #1
    Join Date
    Apr 2009
    Location
    Toms River
    Posts
    85
    Post Thanks / Like
    Exclamation Charging issue
    My 03 obviously has a charging issue, if I drive for any distance other than a short run the battery goes dead. I replaced the battery about a year ago with one that had greater cold cranking than stock.
    I just put a multi-meter on the battery and got some strange results. Prior to testing the battery was fully charged and I got a 14.6 reading. After letting it warm up I checked again while running, at idle about the same 14.5 or so. But when I increased the engine speed the readings were all over the place. It dropped down to 5, up to 9, down again, up again to 11, etc.
    If anyone has any ideas on how to narrow down what the issue is I would appreciate any info.
    I know its either the stator or rectifier, was planning on changing out the rectifier first as its easier & cheaper. But if that is just throwing $ at something that isnt the problem, it would be helpful to know.
    Any help is appreciated.
    Thanks
    Scott
  2. #2
    Join Date
    Jun 2011
    Location
    Posts
    4,042
    Post Thanks / Like
    a battery voltage will not go from 14 volts down to 5 and up to 9 in a second or 2... have the battery LOAD TESTED at an auto parts store.. maybe a broken connection inside of battery or you have a broken battery cable ... check them both red and black...
  3. #3
    Join Date
    Apr 2009
    Location
    Toms River
    Posts
    85
    Post Thanks / Like
    MAY have found the problem. I tightened the battery terminals with a socket, both were slightly loose.
    Rechecked and now it looks like I have around 13.6 volts regardless of rpm.
    Keeping fingers crossed......
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Oct 2010
    Location
    Woodbridge,VA
    Age
    53
    Posts
    327
    Post Thanks / Like
    Check it with the engine off, key off. Start engine, meter should drop while starting and climb to 13.6-14.5ish engine running. Just a quick way check.
  6. #5
    tomkat100's Avatar
    tomkat100 is offline Senior Member
    Missouri Riders Group
    Oklahoma Riders Group
    Join Date
    Jul 2009
    Location
    Rogers, Arkansas
    Age
    75
    Posts
    3,913
    Post Thanks / Like
    Quote Originally Posted by No1rascal View Post
    Uncross your fingers. You found the problem before 20 members told you to try exactly what you did! Congrats on solving your problem.
Thread Information
Users Browsing this Thread
    1. Charging voltage
      By dziadek in forum Honda VTX 1300 Forums
      Last Post: 05-20-2013, 06:56 PM
    2. Charging System Issue - help! Think I have a bad charging coil.
      By kmartburrito in forum Honda VTX 1300 Forums
      Last Post: 07-18-2012, 10:41 AM
    3. Urgent Help Bike wont start. I think its a charging issue but I want another opinion
      By 66chevelle in forum Honda VTX 1300 Forums
      Last Post: 03-14-2012, 11:39 AM
    4. Charging issue
      By NCVTX1300 in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 12-29-2010, 10:42 AM
    5. Charging problem
      By richreynolds976 in forum Honda VTX 1300 Forums
      Last Post: 05-18-2008, 12:40 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
