Front Brakes VTX 1300 Retro
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Front Brakes VTX 1300 Retro
  1. #1
    Join Date
    Jul 2007
    Location
    Fayetteville Georgia
    Posts
    43
    Post Thanks / Like
    I have the pads. But when I go and look at the VTX forum showing how to replace front brakes, the link to the exploded view does not work.
    Anyone have the instructions on how to take hte pads out and put new ones in?
    I got over 15,000 miles on the ones on the bike and I know I need new ones.
    Thanks, Ray
  2. #2
    poolmaster79's Avatar
    poolmaster79 is offline Administrator
    South Carolina Riders Group
    North Carolina Riders Group
    Join Date
    May 2007
    Location
    Greenville
    Age
    38
    Posts
    3,395
    Post Thanks / Like
    PM me your email address and I'll email you the page out of the service manual that covers the front brakes.
  3. #3
    Big-X's Avatar
    Big-X is offline Cafe Founder & VTX lover
    Join Date
    Jul 2005
    Location
    Charlotte
    Age
    53
    Posts
    9,655
    Post Thanks / Like
    Real simple, just make sure you have a c-clamp to compress the piston.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    May 2007
    Location
    Greenville
    Age
    38
    Posts
    3,395
    Post Thanks / Like
    Well, there you go. Thanks Ray.
  6. #5
    Join Date
    Jul 2007
    Location
    Posts
    43
    Post Thanks / Like
    Hey guy, thanks
    Only problem is the first one with the 3 graphics was very hard to read.
    I mean to the point of not being able to read.
    I just need the front brake if you can make that larger and darker I would appreciate it.
    By the way I see your a traveling man. I am awaiting my initiation and then will start my catechism. Also noticed your in SC. I bought a home in Myrtle Beach and will retire in 3 years to that house.
    later,
    Ray
  7. #6
    Join Date
    Jul 2007
    Location
    Posts
    43
    Post Thanks / Like
    Just came in from the garage
    So does PoolMaster mean swimming or billiards. Interesting.
    Anyway, I dont see in the instructions where it says to loosen and pivot.
    It appears you have to slide the pads out and slide new ones in up against a spring of sorts. Really hard to see.
    Confused about the Pad pin and pad pin plug.
    I dont see the pad pin but I do see the plug.
    Do you use a large screw driver with the pad plug?
    Have you dont this before. I know once I have done it it will be easier next time. I dont want to take the pads out unless I feel I can get the new ones in.
    It also talks about depressing piston before you start. All I can figure is they want you to use a screw driver or something to push the piston back while the old pads are still in.
    I believe you said have c clamp. Why? I never see where you can pivot the caliper to depress the piston? Bumper is in the way even if you could.
    Sorry for all the questions.
    Ray
  8. #7
    Goldsmith's Avatar
    Goldsmith is offline Senior Member
    Join Date
    Nov 2005
    Location
    Fort Mill, SC
    Age
    52
    Posts
    5,863
    Post Thanks / Like
    Spotor, there is a link to a download for the 1300 service manual on here. Run a search and if you have cable or wireless broadband you should be able to download it. It is a large file!
  9. #8
    Join Date
    May 2007
    Location
    Greenville
    Age
    38
    Posts
    3,395
    Post Thanks / Like
    Pool as in billiards. Good luck on your journey.
    Like I said, pm me your email address and I will send you that page out of the service manual. As for your questions, I don't know. I've never changed the pads on my X.
  10. #9
    Join Date
    Jul 2007
    Location
    Posts
    43
    Post Thanks / Like
    Hello
    Not sure about PMing. I went to your profile and sent you a note.
    Well your 29 and I am 52 so I have been around. Like I said just getting to be a Mason. And as for billiards would be cool to shoot.
    I used to be a level 9. Got my own table and used to be on leagues.
    Well maybe you can PM me so I can see how it works? I should have a profile here.
    Thanks again,
    Ray
  11. #10
    Charlie D's Avatar
    Washington State Riders Group
    Oregon Riders Group
    Join Date
    Aug 2006
    Location
    seatac, Washington
    Age
    60
    Posts
    18,411
    Post Thanks / Like
    Quote Originally Posted by Spotor1 View Post
    Ray
    You remove the plug then you use an allen wrench to take out the pin.
    it took me all of 15 minutes and I took caliper off leaving the brake line attached so I would not need to bleed them.
    use some brake clean to get rid of the grime and the pistons will push back by some finger preasure or a small block of wood to pry them,
    pads line up in slots then pushed up in place and pin put in make sure you clean the pin and use a very small amount of high temp greese on it.
    mount back on the fork with some blue locktight on the bolts then tighten the pad pin and install the plug.
    you will have to pump the brake several times to relocate the pistons you pushed back then you are ready to go.
Thread Information
Users Browsing this Thread
    1. 21" Front Wheel w/RETRO OEM Fender
      By ioshen in forum Honda VTX 1300 Forums
      Last Post: 04-06-2015, 10:49 PM
    2. New VTX 1300 Retro Rider
      By dellie710819 in forum Introduce yourself and say hello if you like...
      Last Post: 06-01-2008, 12:07 AM
    3. 1300 brakes?
      By fhbrandenburg in forum General VTX/Motorcycle Topics
      Last Post: 10-03-2006, 08:49 AM
    4. Retro Front Brake Line Fitting
      Last Post: 09-28-2006, 05:04 PM
    5. Info on Metzeler front tire for 1300 retro
      By blkxride in forum Honda VTX 1300 Forums
      Last Post: 12-08-2005, 04:50 PM
    Tags for this Thread
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
