Question 1300 Engine Oil Level??
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 1300 Engine Oil Level??
  1. #1
    Join Date
    Aug 2008
    Location
    Key West
    Posts
    34
    Post Thanks / Like
    Hmm2 1300 Engine Oil Level??
    Hello All, I just did my 600 mile initial oil change on my 1300R. I had noticed before the oil change that the oil level was a little high (according to the marks on the factory dip stick). I new I would be changing the oil soon so I did not think much about it. I changed the oil following the shop manual's instruction and added 3.9 Quarts of new oil. I started the bike, warmed her up, shut her down, waited a short while for the oil to settle into the pan, and checked the level. The level is still showing high. It is well above the factory marked upper limit on the dip stick. Is this normal? The stated oil capacity for the bike, when draining oil and replacing the filter, is 3.9 quarts. This is exactly what I added. Can the dip stick be calibrated wrong? I manage a diesel repair shop and have seen this in new engines before. Appreciate the help - thanks.
  2. #2
    Join Date
    Jul 2008
    Location
    Dalton
    Posts
    6
    Post Thanks / Like
    are checking the level with it straight up or on the kickstand?
  3. #3
    Join Date
    Sep 2008
    Location
    saint augustine
    Posts
    53
    Post Thanks / Like
    Note: dipstick does not get screwed in when checking oil, if you didn't know already.
    I just did my 600 mile oil change but used the longer oil filter so I used a whole 4 quarts basically.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Jun 2008
    Location
    Boston
    Posts
    305
    Post Thanks / Like
    check it upright and don't screw in the stick...
  6. #5
    Join Date
    Aug 2008
    Location
    Talladega
    Age
    40
    Posts
    14
    Post Thanks / Like
    Alot of people do this......I just put a couple blocks under the kickstand to check mine......tryed it sitting on bike but just wasnt that flexible enough.....ha....jp
  7. #6
    Blue Goose's Avatar
    Blue Goose is offline Got Goose?
    New Hampshire Riders Group
    Massachusetts Riders Group
    Join Date
    Aug 2008
    Location
    Back home in
    Age
    52
    Posts
    632
    Post Thanks / Like
    I asked the same questions a few weeks ago...it should be fine...mine is reading a tad high sometimes depending how "flexible" I am
    I like the block of wood thing...I'll have to try that!
    2T2
  8. #7
    whiskeyrockr's Avatar
    whiskeyrockr is offline shock factor unrated
    South Carolina Riders Group
    North Carolina Riders Group
    Join Date
    Jun 2008
    Location
    Sandhills
    Age
    48
    Posts
    12,435
    Post Thanks / Like
    block of wood works just fine. +1 on not screwing the dip stick in, just wipe it off and sit it back in and then check it, you should be fine then..
  9. #8
    Charlie D's Avatar
    Washington State Riders Group
    Oregon Riders Group
    Join Date
    Aug 2006
    Location
    seatac, Washington
    Age
    60
    Posts
    18,406
    Post Thanks / Like
    after you know it is correct put back on the stand and check again then file a mark on the stick and never ever have to check in the upright position again.
  10. #9
    Join Date
    Aug 2008
    Location
    Key West
    Posts
    34
    Post Thanks / Like
    Thanks everyone for the replies. Charlie D- great idea on filing a notch with the bike is on the stand. FYI- I have been checking with the bike upright and not screwing in the cap. This is when the oil level reads a little high with 3.9 quarts in it.
  11. #10
    Join Date
    Jun 2008
    Location
    RIO GRANDE
    Posts
    150
    Post Thanks / Like
    I Have The Same Issue. I Changed The Oil Yesterday And It Does Read High At 3.9 Quarts.
Thread Information
Users Browsing this Thread
    1. 1300 engine & H.P. improvements
      By rhess58 in forum Introduce yourself and say hello if you like...
      Last Post: 08-04-2008, 11:07 AM
    2. Engine Idle Speed Adjustment Questions 2005 1300 C
      By JMike in forum Honda VTX 1300 Forums
      Last Post: 04-06-2008, 08:45 AM
    3. Engine vibration of 1800 vs. 1300
      By MidTNRider in forum Honda VTX 1800 Forums
      Last Post: 12-12-2007, 01:10 PM
    4. vtx 1300 engine noise
      By Allen Kotara in forum Honda VTX 1300 Forums
      Last Post: 05-20-2007, 07:03 AM
    5. Tach/Engine Redline on VTX 1300
      By Retro Rich in forum Honda VTX 1300 Forums
      Last Post: 09-04-2006, 09:37 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
