How To: $12 Coolant Pressure Tester
Results 1 to 10 of 10
Thread: How To: $12 Coolant Pressure Tester
  1. #1
    Join Date
    Aug 2011
    Location
    Tampa
    Posts
    58
    Post Thanks / Like
    For when you've swapped the engine or messed with the radiator and know you have a leak.
    Need:
    Radiator Overflow Tubing - $2
    Cheap Bicycle Tire Pump (one w/ a cone adapter) - $10 @ Walmart
    How To:
    0) Remove the tank
    1) Disconnect the overflow hose from you radiator cap
    2) Mount the new tube
    3) Connect the pump to your tube
    4) Unbolt the thermostat housing (not technically necessary but it makes it easier to see/check the hoses)
    5) Spray the area with soapy water
    6) Pump and watch for active bubbling
    Images with notes below:
    The disconnected hose is the actual overflow hose. It's a pain in the ass to re-route so just spend the extra $2 and save yourself the trouble. Note that the thermostat housing unit is unbolted from it's frame bracket and that there is a new hose clamp behind it. That's where my leak was and that's the simplest way to fix it. FYI the soapy water trick really really works.
    Detail shot of the hookup and the hose area.
    Detail shot of the cone adapter - in case you're like me and had never seen one before.
  2. Thanksnate6966 thanked for this post
  3. #2
    MR VTX's Avatar
    MR VTX is offline There Can Only Be One
    Texas Riders Group
    Join Date
    Aug 2005
    Location
    Magnolia
    Age
    45
    Posts
    1,595
    Post Thanks / Like
    Brilliant. I've been trying to figure out how to pressurize my system without forking over $80+ dollars for one of those kits. Thank you!!!
  4. Thanksnate6966 thanked for this post
  5. #3
    Join Date
    Aug 2014
    Location
    Upper Right Ohio
    Age
    65
    Posts
    2,527
    Post Thanks / Like
    where was the internet... in 1977...... had a similar thing. for goldwings.. but using a bicycle Hand pump...
    Well Done...
  6. Remove Advertisements
    VTX Cafe
    Advertisements
  7. #4
    MR VTX's Avatar
    Texas Riders Group
    Join Date
    Aug 2005
    Location
    Magnolia
    Age
    45
    Posts
    1,595
    Post Thanks / Like
    I was trying yesterday to take my old radiator cap and turn it into a pressure tester using a tire valve stem...this is much easier and simpler.
  8. #5
    Join Date
    Jul 2016
    Location
    Johnsonville, NC
    Age
    52
    Posts
    812
    Post Thanks / Like
    Nice. How high did you get the pressure to before you found the leak?
  9. #6
    Join Date
    Aug 2014
    Location
    Upper Right Ohio
    Age
    65
    Posts
    2,527
    Post Thanks / Like
    if memory is STILL good. (not likely) is 12 PSI... what the cap should be rated at.. it might be in the service manual..
    most small leaks can be detected at 4psi...
  10. ThanksRJ64 thanked for this post
  11. #7
    MR VTX's Avatar
    Texas Riders Group
    Join Date
    Aug 2005
    Location
    Magnolia
    Age
    45
    Posts
    1,595
    Post Thanks / Like
    I'm only going to a max of 15 psi. I'll be using this tonight on my bike...gotta get a pump with cone adapter today while I'm out.
  12. #8
    Handyman's Avatar
    Handyman is online now Senior Member
    Kentucky Riders Group
    Join Date
    Jul 2009
    Location
    Shepherdsville, Ky
    Posts
    1,301
    Post Thanks / Like
    Good idea! Don't need it now but will in the future, Thanks!
  13. #9
    SPARKY5151's Avatar
    SPARKY5151 is offline Senior Member California Riders Group
    Join Date
    Aug 2012
    Location
    Central Valley, CA
    Age
    65
    Posts
    2,511
    Post Thanks / Like
    Yes, I wouldn't go over 15 psi when testing as that is about the max pressure that I have ever seen a cap rated for. In fact I would probably start at 7 psi check for leaks and only then raise pressure to 15 psi if you still haven't found the leak!!
  14. #10
    MR VTX's Avatar
    Texas Riders Group
    Join Date
    Aug 2005
    Location
    Magnolia
    Age
    45
    Posts
    1,595
    Post Thanks / Like
    So I did a preliminary test last night, pressurizing the system to about 15 psi. I definitely have a leak, and I think it is the actual filler neck...reason being I just bought a new radiator cap and had it tested at AutoZone, and it held pressure fine. I can hear air escaping, and if I press down on one side of the cap, it gets a little louder. It was late and I was tired, so I didn't use soapy water. I will do that next to pinpoint where the air is escaping from. It could also be the hose I was using, because I forgot to clamp it down before running the test. Ooops.
Thread Information
Users Browsing this Thread
    1. $12 Coolant System Tester and Very Specific Hose
      By jmanwarhammer in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 10-05-2015, 10:01 PM
    2. coolant reservoir is at full line low coolant in radiator?
      By Cocarseller in forum Honda VTX 1300 Forums
      Last Post: 07-23-2015, 06:23 PM
    3. Urgent Help Oil pressure leak problem / pressure plug blown
      By bhbare in forum Honda VTX 1800 Forums
      Last Post: 07-31-2011, 09:52 AM
    4. can i mix regular coolant with HONDA's orginal coolant?
      By footprintsinconc in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 02-27-2011, 06:14 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
