Dark side question
Results 1 to 9 of 9
Thread: Dark side question
  1. #1
    74+ is offline Senior Member Virginia Riders Group
    Join Date
    Aug 2013
    Location
    Manakin Sabot
    Age
    78
    Posts
    133
    Post Thanks / Like
    Whatever Dark side question
    Before going "darkside" I read where folks were getting 30,000+ miles on their General Altimax tires. I have 15,000 miles on mine and they are down to the wear bars in the middle of the tire with lots of tread left on the outsides. I'm running between 42 and 45 PSI per recommendations from forum members and am looking for any ideas you guys might have. Maybe I should try the Michelins next?
  2. #2
    Join Date
    Feb 2014
    Location
    Riverton
    Age
    28
    Posts
    70
    Post Thanks / Like
    I never ran more than 40 in my GA and just sold the bike, the CT still looked brand new. What was the size? I did only have around 8000 on the tire, but still, seems fast to be gone at 15000.
  3. #3
    Join Date
    Sep 2014
    Location
    Hesperia, Calif
    Posts
    1,855
    Post Thanks / Like
    To hard, typical wear pattern for over-inflated...
    Car tire ~ drop down to 35 # and adjust from there...
    Bike is MUCH lighter then car, less pressure needed....
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Aug 2013
    Location
    Manakin Sabot
    Age
    78
    Posts
    133
    Post Thanks / Like
    205/65-r16 general altimax
  6. #5
    Join Date
    Jul 2011
    Location
    Johnstown, Pa.
    Posts
    10,271
    Post Thanks / Like
    Answered your PM. Yeah- too much air. 38# here, maybe less for some. Different road surfaces, rough limestone asphalt as opposed to smoother concrete?
  7. #6
    Join Date
    Feb 2014
    Location
    Winston-Salem, NC
    Posts
    655
    Post Thanks / Like
    I run 38 psi (cold) in mine. I have bags and often ride 2-up. I've got over 19K on my Altimax now, and it's still got plenty of life left.
    Another factor could be balance. I have Dynabeads (actually I used 3oz of the plastic Air-Soft BB's).
    I have the FOBO Bike tire pressure monitors installed. On hot summer days, pressure increases between 4-5 psi when cruising anything over 10 miles.
    Now that it's cooler, and the roads aren't as hot, the pressure increases 3-4 psi.
  8. #7
    sumdatx's Avatar
    sumdatx is offline Deplorable Member
    Join Date
    Nov 2011
    Location
    Vinton,Virginia
    Age
    68
    Posts
    5,245
    Post Thanks / Like
    I've got a couple thousand miles now on a Michelin Defender. I picked this one after having bad experiences with an Altimax RT43 (205/70-15). Since you have a 16" rear wheel, you have some excellent choices with a shorter sidewall giving you more stability. But yeah, you had too much air and the wear pattern indicated it.
    I'm running a 205/65-15 on my 1300. I set it up at 39 psi cold. Seems happy at that point, wear is even so far, cornering is like a normal m/c tire (or so close to it I don't feel much of a difference at this point).
    I did better research this time around and found many folks liked the Michelin Defender quite a bit. One was "Wayne" out west, a longtime Darkside tester. His info is based on practical experience.
    Ray offers up some good points. No 2 tires will ever be exactly the same construction so it stands to reason you have to test out different pressures to get at the one that fits you.
  9. #8
    Join Date
    Apr 2010
    Location
    Burlington ON Canada
    Posts
    4,920
    Post Thanks / Like
    3rd season General Altimax, 40-42 lbs and fantastic wear, still looks new.
    Are you a largish fellow or run rough surfaces regularly?
  10. #9
    wren's Avatar
    wren is offline Senior Member
    Ohio Riders Group
    Join Date
    Dec 2006
    Location
    Where I want to be
    Posts
    947
    Post Thanks / Like
    When I lived in flatland I'd get 30k or so out of a CT. Now that I live in the land of hills and curves I get about 20k. By comparison flat land I'd get 15-17k out of a MC tire and down here I'd get 8-9k so I guess the wear I get from a CT now is probably realistic.
    Now, I do wear the center tread harder but I keep higher pressures due to the aggressive curving I do.
    Wren
  11. ThanksPaXman11 thanked for this post
Thread Information
Users Browsing this Thread
    1. Question for those of you on the dark side
      By Andy27012 in forum General VTX/Motorcycle Topics
      Last Post: 12-09-2015, 10:56 AM
    2. Dark side Question
      By Loco dog in forum Honda VTX 1800 Forums
      Last Post: 05-05-2014, 04:21 PM
    3. Dark side question
      By Sprocket in forum Honda VTX 1800 Forums
      Last Post: 03-20-2013, 09:10 PM
    4. dark side question
      By tncruzer1300 in forum Honda VTX 1300 Forums
      Last Post: 10-27-2010, 11:45 PM
    5. Dark side question
      By bjcsharp3 in forum Honda VTX 1300 Forums
      Last Post: 05-03-2009, 06:13 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
