Brake Pedal
Results 1 to 9 of 9
Thread: Brake Pedal
  1. #1
    Join Date
    Nov 2016
    Location
    Mountain Home
    Posts
    5
    Post Thanks / Like
    Brake Pedal
    My rear brake pedal requires quite a bit of throw to engage the brakes. Is this normal? The pedal is parallel to the ground before it takes effect.
  2. #2
    Fishingfoolemjak's Avatar
    Fishingfoolemjak is offline Mental Member Tennessee Riders Group
    South Carolina Riders Group
    North Carolina Riders Group
    Join Date
    Jul 2016
    Location
    Sylva, NC
    Age
    43
    Posts
    2,140
    Post Thanks / Like
    May want to check the fluid levels.... but I know mine takes a bit as well.
  3. #3
    Join Date
    Aug 2014
    Location
    Upper Right Ohio
    Age
    65
    Posts
    2,337
    Post Thanks / Like
    bleed system.. EVERY 2 YEARS. its in the manual.
    its a LINKED SYSTEM. read the manual.. download for Free... year of manual does NOT matter... all 1800 is same for the brakes.
    Linked means front and rear are connected.. and has a Special procedure to do it. Its NOT Difficult... just different.
    Old Fluid should be Clear or Light Yellow.. any darker is overdue for replacement. my opinion.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Jul 2016
    Location
    Johnsonville, NC
    Age
    52
    Posts
    615
    Post Thanks / Like
    The brake fluid on my bike, that the dealer claims was changed, looked about like coffee. I flushed it all out good. My pedal doesn't move that far, but this is my first linked brake system bike so I wasn't sure about being 'normal' or not. Stops good and too good if I push it too hard. I have lost miles off the back tire until I found the 'sweet spot'.
  6. ThanksFishingfoolemjak thanked for this post
  7. #5
    mjklaser's Avatar
    mjklaser is offline ~ High-Finesse Hooligan ~
    New Hampshire Riders Group
    Join Date
    May 2009
    Location
    New Hampshire
    Age
    54
    Posts
    5,094
    Post Thanks / Like
    Quote Originally Posted by RJ64 View Post
    The brake fluid on my bike, that the dealer claims was changed, looked about like coffee...
    ...damn stealers
  8. #6
    Join Date
    Jul 2016
    Location
    Johnsonville, NC
    Age
    52
    Posts
    615
    Post Thanks / Like
    Quote Originally Posted by mjklaser View Post
    ...damn stealers
    I really really really can't stand liars. There is no reason for that. I don't know if they learned a lesson, but I did
  9. Thanksmjklaser thanked for this post
  10. #7
    Join Date
    Aug 2014
    Location
    Upper Right Ohio
    Age
    65
    Posts
    2,337
    Post Thanks / Like
    I have quit a few mechanics jobs... owner/managers lack of honesty to the customers. Dealers and repair shops.
    you may not like what is say.. but it will be the truth as I know it.
  11. ThanksFishingfoolemjak thanked for this post
  12. #8
    Join Date
    Sep 2016
    Location
    Paradise
    Posts
    152
    Post Thanks / Like
    Quote Originally Posted by Silver F View Post
    Amen brother, brake fluid is cheap and the bleeding process not difficult. It sure beats having to rebuild calipers and replace lines
    A little maintenance goes a long way to saving $$$
    Do you recall this commercial?
  13. #9
    wren's Avatar
    wren is offline Senior Member
    Ohio Riders Group
    Join Date
    Dec 2006
    Location
    Where I want to be
    Posts
    946
    Post Thanks / Like
    Haven't had to look at the 1800 rear brake master cylinder except for normal bleeding but the 1300 is adjustable at the rod between the master cylinder and the brake lever attached to the pedal. Bit of a pain getting to it but I've made that adjustment numerous times for folks.
    It comes to mind because you said nothing about a soft hand brake and with the linked system you are having a problem only from the foot brake so I'd be looking at that.
    Wren
Thread Information
Users Browsing this Thread
    1. Brake pedal
      By wngd in forum Honda VTX 1300 Forums
      Last Post: 02-07-2012, 12:56 PM
    2. R to C brake pedal
      By vtxillini in forum General VTX/Motorcycle Topics
      Last Post: 08-26-2009, 12:36 AM
    3. brake pedal
      By charlie_fu in forum Honda VTX 1300 Forums
      Last Post: 11-25-2008, 11:07 AM
    4. Foot brake pedal brake light activation
      By tighr in forum Honda VTX 1300 Forums
      Last Post: 10-30-2008, 05:53 PM
    5. Brake pedal
      By punkslapper in forum Honda VTX 1300 Forums
      Last Post: 02-05-2008, 12:27 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
