Can Not Read Your Odometer ? Here is a Fix for the problem...
Results 1 to 2 of 2
Thread: Can Not Read Your Odometer ? Here is a Fix for the problem...
  1. #1
    Join Date
    Sep 2016
    Location
    Williston,
    Posts
    4
    Post Thanks / Like
    [Hey Guys, I have a fix for the problem.. I found that the samsung polarizers worked but the adhesive was on the wrong side for our use.... What I had to do was turn the polarizers to find the best position to few the odometer, then cut two pieces of film 1/2 x 1 1/2 inches. Peel off the protective cover of the adhesive sides and put them together. Rub the back with a credit card to remove any air that might be trapped. Then peel off the plastic cover on both sides of the film. Now all you have is use your Hot glue gun and put two strips of glue down each side and stick it to your clean lcd odometer. I'm assuming you had removed the old polarizer from the odometer and cleaned , and scraped all the glue off the lcd, I also used alcohol to clean the lcd of remaining glue... Three bucks for 5 samsung lcd polarizers sure beats 300.00 for a new odometer and you will have enough replacement polarizers for the rest of your life..
  2. Thanksmjklaser, Prototype427 thanked for this post
  3. #2
    Join Date
    Feb 2015
    Location
    Ft Myers
    Posts
    560
    Post Thanks / Like
    pics?
Thread Information
Users Browsing this Thread
    1. 1300C trip odometer problem
      By 74+ in forum Honda VTX 1300 Forums
      Last Post: 05-01-2016, 10:57 AM
    2. Will A/F screw fix my problem?
      By Derek-MFD213 in forum Honda VTX 1300 Forums
      Last Post: 04-07-2014, 02:03 PM
    3. Question Hard to read Odometer
      By oldfolks1 in forum Honda VTX 1800 Forums
      Last Post: 06-17-2013, 04:58 AM
    4. Replies: 14
      Last Post: 10-27-2011, 01:31 PM
    5. Odometer problem
      By nivensid in forum Honda VTX 1300 Forums
      Last Post: 04-27-2010, 06:25 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
