Turn signal problems
Results 1 to 4 of 4
Thread: Turn signal problems
  1. #1
    Join Date
    Aug 2006
    Location
    Romeoville
    Posts
    308
    Post Thanks / Like
    Hope someone can help me. I just finished installing a Cobra lightbar and with the help of others, I completed it with no issues. I tested the lights and my turn signals this morning and everything worked fine. I went for a ride and 10 miles down the road in a left turn lane I noticed both my dash turn indicators were flashing. All four signals were flashing as well, one was kind of dim, the other three were bright. I don't have emergengy flashers on my bike. Mind you I was turning left. I hit the right turn signals and the both right flashers worked, however they flash very fast and the two left signals burn steady.
    Why they worked fine in the garage and now they are fouled up after a 10 mile ride is beyond me. I labeled the wiring for the signals when I took everything apart to install the lightbar and I believe I have them back correctly. Not to hard of a job, but I'll check them again.
    I've had a Kury RTB unit for the last three years and it works fine. Well, I'm not sure if that thing finally blew when I installed the lightbar, all I did was move it out of the way a bit to get the battery area. I have to use a load equalizer with the RTB, so I don't know of that blew either. I see no blown fuses or bad connections so far.
    Any ideas guys?
    Thanks....
  2. #2
    Join Date
    Jul 2007
    Location
    Canada
    Posts
    421
    Post Thanks / Like
    Quote Originally Posted by Sixgun View Post
    Any ideas guys?
    Thanks....
    Check your bulbs, they all share the ground, so maybe a crossed connection inside the bulb.
    Make the issue happen and start removing bulbs till it stops.
    cheers
  3. #3
    jersrt's Avatar
    jersrt is offline Member
    Pennsylvania Riders Group
    Join Date
    Jul 2008
    Location
    Pittsburgh
    Posts
    73
    Post Thanks / Like
    Try these:
    Sounds like a short, remove all connection and start again, solder all connections and heat shrink or tape very well. If this does not work the problem will be with the load EQ, I got one from Custom Dynamics and chased t a similar prob. for week only to find out the EQ was but, CD sent me a new for free (very nice). Hope this helps...
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Aug 2006
    Location
    Romeoville
    Posts
    308
    Post Thanks / Like
    Found the problem. Was checking the front bulb assembly and when I moved the rats nest of wires in the front bucket, a single green wire which is part of the signal circuit had come loose.
    Thanks guys!!
Thread Information
Users Browsing this Thread
    1. Run-Turn-Brake Turn Signal Conversion Kits
      By one up in forum Honda VTX 1800 Forums
      Last Post: 06-02-2009, 02:21 AM
    2. Front Turn Signal Problems
      By DHJrider in forum Honda VTX 1300 Forums
      Last Post: 08-19-2008, 05:19 PM
    3. Signal light problems
      By Neily06 in forum Honda VTX 1800 Forums
      Last Post: 05-11-2008, 10:07 PM
    4. Turn signal problems in cold weather
      By vegas in forum Honda VTX 1800 Forums
      Last Post: 01-25-2008, 08:19 PM
    5. glen's turn signal beeper and the run, turn, brake set-up
      By mig in forum Honda VTX 1300 Forums
      Last Post: 12-27-2007, 01:47 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
