1300 Rear brake pad R&R Write-up with pics
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 88
Thread: 1300 Rear brake pad R&R Write-up with pics
  1. #1
    Join Date
    Aug 2008
    Location
    Zephyrhills / Tampa
    Age
    55
    Posts
    7,114
    Post Thanks / Like
    I replaced my rear brake pads yesterday and figured while I was at it I would take some pics and do a quick write up.
    It’s a fairly straight forward job that probably takes less than ½ hour provided you don’t have saddlebags to remove.
    Push the caliper all the way in toward the center of the wheel to compress the piston, and make room for the new, thicker pads.
    Remove the plug that covers the pad pin and loosen the pad pin.
    Remove the bracket pin bolt.
    Pivot the caliper up away from the disc, and remove the pad pin and pads.
    A vice grip C-clamp or similar tool can be used to gently compress the caliper piston further if needed, to make room for the new pads.
    Slide the new pads in, seating them on the spring, and install the pad pin hand tight.
    Pivot the caliper back down over the disc and into place. Making sure the ends of the pads seat correctly on the retainer.
    Install the bracket pin bolt and torque to 17 ft/lbs.
    Torque the pad pin to 13 ft/lbs.
    Install the pad pin plug.
    Pump the brake pedal to seat the caliper and pads.
    That's it.
    Ride Safe.
    ----------------------------- ORIGINAL INSTRUCTION RETAINED IN CASE SOMETHING IS MISSING IN THE NEW POST.
    -John
    Added in from Re-post with new images:
    The pictures from my original thread have disappeared, and I have had several request for this thread so I have remade the original post.
    Hope it helps.
    First, push the caliper all the way in toward the center of the wheel to compress the piston, and make room for the new, thicker pads.
    Clean all caliper and rotor parts well with brake cleaner spray.
    Lubricate the bracket pin bolt so that the caliper will slide easily, re-install the bolt and torque to 17 ft/lbs.
    Install the pad pin plug. Torque to 2.2 ft/lbs.
    That's it.
    Ride Safe.
    -John
    Last edited by Mortikus; 03-22-2012 at 01:03 PM. Reason: Combining threads for sticky.
  2. #2
    Bassdude404's Avatar
    Bassdude404 is offline The guitar, not the fish!
    Ohio Riders Group
    Michigan Riders Group
    Indiana Riders Group
    Illinois Riders Group
    Join Date
    Sep 2007
    Location
    Rolling Prairie, Indiana
    Age
    53
    Posts
    33,378
    Post Thanks / Like
    Hood job!!...Folks taking pics of jobs while doing them really helps the guys out that have never done said job...
  3. #3
    Join Date
    Aug 2008
    Location
    Zephyrhills / Tampa
    Age
    55
    Posts
    7,114
    Post Thanks / Like
    Quote Originally Posted by Bassdude404 View Post
    Thanks Bass,
    I think it took longer to do the post than it did to replace the pads, but I figure if it helps someone else it's well worth it.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Gonzo1970's Avatar
    Gonzo1970 is offline Equito Passim
    Missouri Riders Group
    Join Date
    Sep 2009
    Location
    Belleville, IL
    Age
    47
    Posts
    9,123
    Post Thanks / Like
    Nice write up! I had done brakes on cars tons of times, so brakes on a bike wasnt much different. But nice to have since there can be those "little details" that one might not know about.
    Thanks!
    -Gonz
  6. #5
    Join Date
    Dec 2006
    Location
    Palmetto FL
    Posts
    373
    Post Thanks / Like
    Thanks JStar ,been holding off doin mine,after reading your write-up gives me confidence.Always done the brakes on my cars and trucks just never on a bike
  7. #6
    Charlie D's Avatar
    Washington State Riders Group
    Oregon Riders Group
    Join Date
    Aug 2006
    Location
    seatac, Washington
    Age
    60
    Posts
    18,423
    Post Thanks / Like
    nice only 2 things I have to offer is have a can of spray brake clean and some high-temp grease.
    brake clean to remove the dust and build up on the calipers and to clean the rotor, and as per the book the lock pin on the caliper that holds the pads is supposed to have a light coating of high-temp grease on it to keep it from binding.
  8. #7
    Join Date
    Aug 2008
    Location
    Zephyrhills / Tampa
    Age
    55
    Posts
    7,114
    Post Thanks / Like
    Quote Originally Posted by Charlie D View Post
    Thanks Charlie, good points.
  9. #8
    Join Date
    Oct 2008
    Location
    Sebring, Florida
    Age
    58
    Posts
    9,160
    Post Thanks / Like
    Nice post, thanks.
  10. #9
    Join Date
    May 2009
    Location
    Raleigh
    Age
    72
    Posts
    2,670
    Post Thanks / Like
    Good Post Jstar.
  11. #10
    Goldsmith's Avatar
    Goldsmith is offline Senior Member
    South Carolina Riders Group
    North Carolina Riders Group
    Join Date
    Nov 2005
    Location
    Fort Mill, SC
    Age
    52
    Posts
    5,863
    Post Thanks / Like
    Good job Jstar. I really cannot believe you forgot the lube(grease) after that thread! LOL
    You have done us all a great service in taking the time to shoot pics and put the particulars on here!
Thread Information
Users Browsing this Thread
    1. 1300 Left side rear brake set up?
      By Fried Okra in forum Honda VTX 1300 Forums
      Last Post: 11-13-2008, 01:58 PM
    2. Rear Brake Question
      By VTX-Ward in forum Honda VTX 1300 Forums
      Last Post: 06-02-2008, 09:07 AM
    3. VTX 1300 Rear Brake Pads installation
      By Spotor1 in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 03-16-2008, 12:42 AM
    4. For Sale: OEM 1300 C Rear Brake Assembly
      By ioshen in forum 1300 Parts /Accessories For Sale
      Last Post: 08-09-2007, 10:18 AM
    5. Bad rear brake caliper?
      By John Savage in forum General VTX/Motorcycle Topics
      Last Post: 07-18-2007, 12:18 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
