License Plate Light/Assembly Removal
Results 1 to 3 of 3
Thread: License Plate Light/Assembly Removal
  1. #1
    Join Date
    Dec 2010
    Location
    Nolensville
    Age
    69
    Posts
    719
    Post Thanks / Like
    I have a 2009 VTX1300R and I have some plans for altering the license plate frame assembly. I want to add additional running lights and another (flashing) stop light.
    Does the entire assembly remove pretty easily? Does the wiring for the license plate light unplug or will I need to cut and splice wiring? If I need to interface the wiring from the stop light circuit, is that a matter of cutting wires too?
    I realize that as I start removing things, a lot of my questions will be answered but I thought I could also take advantage of the knowledge base here before starting the project.
    I bought a 3" flashing LED module from a police supply store, fired it up and that sucker darn near blinded me. I guess I'll have to tone it down somehow.....but it sure is effective as an added stop light.
  2. #2
    Join Date
    Jun 2010
    Location
    West Palm, Fl
    Age
    54
    Posts
    1,303
    Post Thanks / Like
    If your talking about the license plate holder itself, and not the whole tail light assembly, it's a matter of 3 nuts on the inside of the fender. I removed mine a few weeks ago. The whole tail light assembly is a different story. That info I will be interested in also!
  3. #3
    Join Date
    Oct 2010
    Location
    Forks Township
    Posts
    1,959
    Post Thanks / Like
    Is this what you are looking for regarding the plate assembly?
    Of course, if you want it activated when you brake, you will need to tap into the brake light assembly. It is a plug but to really get to it, you need to remove the fender.
    Basically after removing the fender, you have easy access to the harness clamp. the wires I think are too short for you to reach up there and do anything with.
    On the R you need to remove the seat and both side covers then remove the shock absorbers then you can get in and disconnect the clamp.
    Then you need to remove the shock absorber upper pivot bolts and take off the grab rails. Now the fender can come off. It's a bit heavy and to make sure you don't dip and scratch, you may want to have another set of hands around.
Thread Information
Users Browsing this Thread
    1. License Plate holder removal
      By h2omagnet in forum Honda VTX 1300 Forums
      Last Post: 11-04-2010, 05:10 PM
    2. Urgent Help Licesnce plate & turn signal assembly removal question?
      By Glock-45 in forum Honda VTX 1300 Forums
      Last Post: 06-28-2010, 02:49 PM
    3. 2007 vtx1300c Brake light/tail light and license plate light help
      By hook_em! in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 11-08-2009, 08:23 PM
    4. License Plate Removal
      By Prflyer26 in forum Honda VTX 1300 Forums
      Last Post: 03-11-2009, 03:24 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
