What causes an ENGINE TO HAVE HIGH COMPRESSION?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: What causes an ENGINE TO HAVE HIGH COMPRESSION?
  1. #1
    Join Date
    Oct 2010
    Location
    suwanee
    Posts
    108
    Post Thanks / Like
    Anyone know what can cause higher than normal engine compression?
  2. #2
    Join Date
    Jan 2011
    Location
    New Glasgow, Nova Scotia
    Age
    54
    Posts
    2,591
    Post Thanks / Like
    How much too high is it?
    How did you discover it was high?
  3. #3
    Join Date
    Oct 2010
    Location
    suwanee
    Posts
    108
    Post Thanks / Like
    I used a compression gauge.
    Reading was double in the rear. The front wasnt quite as high as the rear.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    00 Doc's Avatar
    00 Doc is offline Senior Member
    Oklahoma Riders Group
    Join Date
    Apr 2008
    Location
    NE
    Posts
    528
    Post Thanks / Like
    I've never heard of it but extreme carbon build up could make the combustion chamber smaller, I suppose... Usually a cylinder will loose compression from this due to leaky valves/rings.
  6. #5
    Join Date
    May 2010
    Location
    holbrook
    Age
    77
    Posts
    1,619
    Post Thanks / Like
    I'd check first with a second gauge, it should never be double. Higher compression readings are caused by carbon deposits that are stuck to the top of the pistons.
  7. #6
    Join Date
    Jan 2011
    Location
    Age
    54
    Posts
    2,591
    Post Thanks / Like
    +1 try another gauge to rule out defective tool.
    Quote Originally Posted by bryanova View Post
  8. #7
    Bassdude404's Avatar
    Bassdude404 is offline The guitar, not the fish!
    Ohio Riders Group
    Michigan Riders Group
    Indiana Riders Group
    Illinois Riders Group
    Join Date
    Sep 2007
    Location
    Rolling Prairie, Indiana
    Age
    52
    Posts
    33,361
    Post Thanks / Like
    Let's see...Double compression would be somewhere in the area of 18:1 (just a guess as I don't know what the actual CR is for an 1800)...That would be too high for premium pump gas (limits there are about 14:1 max), and you would have so much detonation going on that you would've already burned holes in both pistons...I'd be checking to make sure that gage is accurate...
  9. #8
    Join Date
    Feb 2009
    Location
    Northern
    Posts
    264
    Post Thanks / Like
    i think the manual specified 95psi per cylinder, but i have heard of people with up to 120 psi per cylinder. The only explanation for this problem,
    carbon buildup in the combustion area. Maybe try some Lucas fuel additive to clean the injectors and carbon buildup. Good luck! O~by the way, What were your compression readings!!!!
  10. #9
    Join Date
    Feb 2011
    Location
    Maricopa
    Posts
    743
    Post Thanks / Like
    Faulty decompression cam.
  11. #10
    Join Date
    Feb 2009
    Location
    Northern
    Posts
    264
    Post Thanks / Like
    Quote Originally Posted by bigjon View Post
    faulty decompression cam.
    +1 ........
Thread Information
Users Browsing this Thread
    1. Compression High on Both Cylinders--WHAT CAN HELP
      By mattressman08 in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 02-24-2011, 02:14 PM
    2. For Sale: AFT 1300 Fury/VTX High Compression Kit
      By markamoore in forum 1300 Parts /Accessories For Sale
      Last Post: 12-08-2010, 07:59 AM
    3. Rustoleum High Heat for engine paint?
      By Skeletor in forum General VTX/Motorcycle Topics
      Last Post: 02-22-2010, 04:42 PM
    4. Question High Engine RPM, Gas Millage, Speedo
      By puppymate in forum Honda VTX 1300 Forums
      Last Post: 10-30-2009, 03:05 PM
    5. High Compression Pistons @ High Altitude
      By nicholasdeuce in forum Performance Upgrades/Mods
      Last Post: 05-09-2009, 09:21 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
