Battery YUASA YTX20L-BS vs Walmart ES20LBS
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Battery YUASA YTX20L-BS vs Walmart ES20LBS
  1. #1
    Join Date
    Feb 2009
    Location
    Tallahassee
    Age
    74
    Posts
    1,437
    Post Thanks / Like
    I'm posting some photos of the YUASA YTX20L-BS and Walmart ES20LBS for you to compare. The cases appear to be the same.
    The tops look the same except the Walmart EverStart has a label. the label contains charging instructions and model number YTX20L-BS, which happens to be the model number of the stock YUASA battery.
    The tops are shaped the same the +/- markings are pressed in the same. The posts are the same, both accepting the threaded inserts from the ends. The filler covers look the sane.
    I removed the filler cover and looked at the mechanisms that are used to puncher the Dry Charge Acid Seals and they are the same.
    From the top, the Walmart ES20LBS appers to be identical to the stock YUASA YTX20L-BS.
    The case shape and dimensions are identical. The front labels are different. But the rear labels are identical except for one stamp on the EverStart label. The labels even share a stamp (5PSYMBWPO) on the lower right corners.
    The cases also have engraved characters on the top rear that are very similar.
    If the Walmart ES20LBS is not manufactured on the same line as the YUASA, I'm gonna be surprised.
    Geezer
  2. #2
    Badjuan's Avatar
    Badjuan is offline Senior Member
    Ohio Riders Group
    Join Date
    Feb 2011
    Location
    Xenia, Ohio
    Posts
    438
    Post Thanks / Like
    Are the prices the same?
    badjuan
  3. #3
    Join Date
    May 2010
    Location
    holbrook
    Age
    77
    Posts
    1,619
    Post Thanks / Like
    Quote Originally Posted by Badjuan View Post
    badjuan
    good point, I know the Yuasa batteries are excellent, i also know walmart has to buy that battery from some manufacturer, question, would they buy it from a japanese manufacturer? Interesting post. Bry
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    wanderingbear's Avatar
    wanderingbear is offline Senior Member
    Florida Riders Group
    Join Date
    Oct 2008
    Location
    Frostproof
    Age
    69
    Posts
    27,731
    Post Thanks / Like
    When I bought mine it wasn't a YUASA but it was made by them. I got it from E-bay. WalMarts may be the same way look on it and see if it says who makes it for them.
  6. #5
    Join Date
    Jan 2007
    Location
    Welcome, NC
    Age
    63
    Posts
    178
    Post Thanks / Like
    I will be following this thread... my oem battery is still good in my 2007 VTX, but I'm wondering how long I can really expect it to last.
  7. #6
    Join Date
    Feb 2009
    Location
    Tallahassee
    Age
    74
    Posts
    1,437
    Post Thanks / Like
    The label on the Walmart box says 'Distributed By Johnson Controls' of Milwaukee, WI. Made In The U.S.A.
    Johnson Controls owns Optima Battery and Varta Batteries used in Power Sports equipment. But not YUASA?
    I was impressed by the quality of the terminal hardware. It's stainless steel and American quality machining. Four bolts of two different lengths were supplied.
    Geezer
  8. #7
    Gonzo1970's Avatar
    Gonzo1970 is offline Equito Passim
    Missouri Riders Group
    Illinois Riders Group
    Join Date
    Sep 2009
    Location
    Belleville, IL
    Age
    46
    Posts
    9,123
    Post Thanks / Like
    Quote Originally Posted by Interceptor View Post
    Same here.. except '06
    Last time I was at wally world, they didnt have any sealed batteries for the VTX, only the "Add Acid and Charge" type. And I don't like those, never have...
    -Gonz
  9. #8
    Mondorah's Avatar
    Mondorah is offline Pie liker/Snow Hater
    Indiana Riders Group
    Join Date
    May 2009
    Location
    Osceola, IN
    Age
    48
    Posts
    9,887
    Post Thanks / Like
    My battery is dead. Wally World is right around the corner. Guess I'll have to go check em out.
  10. #9
    Join Date
    Sep 2009
    Location
    Rockwell
    Age
    49
    Posts
    341
    Post Thanks / Like
    I remember this subject came up last year in this thread.
    http://www.vtxcafe.com/showthread.ph...ighlight=YUASA
    Post #9 was informative on the subject.
  11. #10
    Mondorah's Avatar
    Join Date
    May 2009
    Location
    Osceola, IN
    Age
    48
    Posts
    9,887
    Post Thanks / Like
    Quote Originally Posted by Cause88 View Post
    Post #13 says I was in the market back then too!
    Now more than then though.
    Great info ther 88! Thanks for posting it.
    Ray
Thread Information
Users Browsing this Thread
    1. Walmart VTX owner?
      By Capelawdawg in forum General VTX/Motorcycle Topics
      Last Post: 03-03-2010, 10:21 PM
    2. MOD the walmart lights first! how I did it.
      By Ammo Man in forum Chrome Parts / Misc
      Last Post: 08-30-2009, 02:02 PM
    3. walmart burners
      By turk1800 in forum Honda VTX 1800 Forums
      Last Post: 09-14-2008, 06:18 PM
    4. walmart
      By fisher in forum Off Topic Discussions
      Last Post: 04-18-2008, 09:37 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
