Fuel Mixture Screw???
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Fuel Mixture Screw???
  1. #1
    Join Date
    Mar 2011
    Location
    Aurora
    Posts
    8
    Post Thanks / Like
    Hey all. My x1300 is running real rich. I had a shadow A.C.E. that did the same thing and I was able to adjust the mixture on it with no problem. I can't seem to locate the screw on th X's carb though. Anybody know exactly where its located? Thx
  2. #2
    Join Date
    Jan 2011
    Location
    New Glasgow, Nova Scotia
    Age
    54
    Posts
    2,591
    Post Thanks / Like
    It's a D-shaped screw behind the fuel bowl near where the carb connects to the intake manifold.
    Do your self a favour and get Glen's permanent A/F adjuster.
    www.glensvtxgarage.com
  3. #3
    wanderingbear's Avatar
    wanderingbear is offline Senior Member
    Florida Riders Group
    Join Date
    Oct 2008
    Location
    Frostproof
    Age
    69
    Posts
    27,731
    Post Thanks / Like
    Are you sure it's rich these bikes tend to run lean.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Donut's Avatar
    Donut is offline Senior Member
    Michigan Riders Group
    Indiana Riders Group
    Join Date
    Jan 2010
    Location
    Coloma,Michigan
    Age
    68
    Posts
    7,390
    Post Thanks / Like
    You are not running rich especially if the bike is stock. The choke is making you think it is running rich. Read this.
    I don’t know why but it seems that a lot of bikes run fine when new but after a couple years they seem to start having these same symptoms. It's sounding more like it is running lean and that the A/F needs to be adjusted. I would consider ordering Glen's Permanent A/F adjuster. It's a little hard to adjust without it. This way you don’t have to remove the gas tank and the air breather box to make any fine adjustment. The knob hangs down beside the idle adjustment on the right side between the lower part of the cylinder's.
    Most of the time you will not need the choke.
    The choke in not a choke, it is an enhancer and dumps a whole lot of fuel in fast. These bikes are set lean from the factory to pass EPA and that is why you are having to use the choke / enhancer. I would suggest you open the A/F up a little more. It is hard to get at and I would recommended you install Glen's permanent A/F adjuster, it makes adjusting much easier.
    The factory sets the A/F at 1 5/8 for the EPA. --” your problem”
    A/F should be set at 2.5
    This will save you a heck of a lot trouble.
    Hers a link;
    Glen's VTX Garage
    Donut
  6. #5
    Join Date
    Nov 2010
    Location
    Columbia
    Age
    59
    Posts
    140
    Post Thanks / Like
    I've read a single report somewhere about a single rider routinely using a D-adjuster tool to change the A/F setting from the left side. He's a better man than I (and I have the tool!)
    About the only way to get at the thing is from the right side, after removing the airbox.
    (If somebody knows a simple and reliable method of reattaching the vacuum hoses to the rear of the stock airbox, please post it! It's been a time-consuming PITA the couple of times I've had it off.)
  7. #6
    Join Date
    Oct 2008
    Location
    Frostproof
    Age
    69
    Posts
    27,731
    Post Thanks / Like
    I have the tool too if anyone around here needs to adjust their carb, just let me know.
  8. #7
    Join Date
    Sep 2008
    Location
    Utica
    Age
    53
    Posts
    5,305
    Post Thanks / Like
    I agree 100% that your more likely running very lean vs rich if your bike is stock.
    Here's where to find the A/F screw
  9. #8
    Join Date
    Mar 2011
    Location
    Aurora
    Posts
    8
    Post Thanks / Like
    Thanks for all the info. the reason I say it is running rich is because when I took off the airbox there was gas in it. and when I fired her up (after sitting all night) she spat gas out of carb. not alot, just when revving her. It had back pressure pop with stock pipes and just changed to cobra slip ons. still has pop. dealer said that it shouldn't need to be jetted. Does that sound right?
  10. #9
    Donut's Avatar
    Join Date
    Jan 2010
    Location
    Coloma,Michigan
    Age
    68
    Posts
    7,390
    Post Thanks / Like
    You might be running lean on the low end ant that can cause the pooing. Are you using the choke and maybe fouling the plugs a little with the choke/enhancer. You don't need jetting with your setup.
    I'd add Glen's permanent A/F adjuster.
    Read this general post that I have.
    Hers a link;
    Glen's VTX Garage
    Donut
  11. #10
    Join Date
    Sep 2008
    Location
    Utica
    Age
    53
    Posts
    5,305
    Post Thanks / Like
    Quote Originally Posted by CoJoe View Post
    It's kinda backwards to what you would think, when it's spitting gas out of the carb into the airbox that's a tell tail sign that it's running lean.
Thread Information
Users Browsing this Thread
    1. Tamper proof plug on Air/Fuel mixture screw
      By sinister in forum Honda VTX 1300 Forums
      Last Post: 06-10-2009, 12:45 PM
    2. A/F Mixture Screw
      By TXMARSHAL in forum Honda VTX 1300 Forums
      Last Post: 05-30-2009, 10:37 PM
    3. fuel mixture screw
      By Guyute in forum Honda VTX 1300 Forums
      Last Post: 06-06-2008, 10:08 AM
    4. Pipes / mixture screw question
      By jay18miscaif in forum Honda VTX 1300 Forums
      Last Post: 06-04-2008, 04:15 PM
    5. A/F mixture screw
      By Warlock4 in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 05-28-2008, 08:21 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
