running rich
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: running rich
  1. #1
    Join Date
    Mar 2011
    Location
    lockport
    Age
    47
    Posts
    21
    Post Thanks / Like
    running rich
    weather sucks here in buffalo ny. mid 40's and rain. only 200 miles on bike so far anyways, I know this question has been beat to death with a VERY large stick but here goes. I have an 07 1300r with lots of goodies on it when i bought it 2 months ago. It seems to be runing a little rich. has Kury Pro-R and stock pipes although I believe they were gutted. ( a lot louder than stock) no holes drilled that i could find. bike runs great. occasional pop on decel. was worse but better after changing bad vacuum line to hyper. would like to know what to look for and how to fix . i have to assume it has been jetted . haven't pulled carb off to check yet.what is the Pair valve mod i have been reading about? How would I know if it has been done? if you guys can post links and pics or anything to help me out that would be great. Thanks in advance
  2. #2
    Join Date
    Aug 2010
    Location
    Danville
    Posts
    122
    Post Thanks / Like
    Have you pulled the plugs to verify Rich Condition?
    Decell popping can be leak in exhaust crush gaskets, LEAN condition, Leak at Pair Valve removal block off plates.
    Pair valve removal http://tech.bareasschoppers.com/engine/vtx-1300-desmog/
  3. #3
    Join Date
    Oct 2010
    Location
    Lutz
    Posts
    875
    Post Thanks / Like
    Paired valve is just like it sounds. It ads alot of hoses to to the system so its hard to miss. One hose does into the back of the intake (not sure where on a hypercharger...). then you will see some other hoses and reed valves connected to the top of the engine. You remove this whole system and put block off plates over the open area. The whole thing is pointless to have, it was just to pass emissions. I still havent done mine so I cant give any specifics besides saying Im sure there is a good write up on here.
    The paired valve removal will help with any decel popping but not so much with running rich. You may want to look into the Scar mod or a Factory Pro Jet Kit for that. I just did the scar mod and it helped tremendously.
    Quote Originally Posted by RandyHut View Post
    And like he said decel popping would be more present in a lean condition than a rich one. If it has been jetted but not properly tuned it could be lean, if it doesnt have a jet or Scar mod its definitely lean.
    I dont know which you should do first but dont do both together. If the bike doesnt run right there are now to many reasons to diagnose. Here are some write up links.
    Scar Mod
    http://www.vtxcafe.com/showthread.php?t=3079
    Scar Video
    http://www.youtube.com/watch?v=TRgkX05P2io
    Lean/Rich Diagnose and Fix
    http://www.vtxcafe.com/showthread.php?t=12511
    Paired Valve (its for a Fury but same setup)
    http://www.furyforums.com/forum/fury...e-removal.html
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    Mar 2011
    Location
    lockport
    Age
    47
    Posts
    21
    Post Thanks / Like
    pulled plugs and verified. it is running rich. popping on decel is very occasional only happened twice since replacing bad hose. like i said, I know this has been beat to death. I have spent hours reading these forums. and am trying to get links together in one place so that i can print them out. of course i would prefer not to tear my bike down cause the weather is gonna break any day now LOL. rain for the next week
  6. #5
    Join Date
    Aug 2010
    Location
    Danville
    Posts
    122
    Post Thanks / Like
    Ok, you are sure it is Rich, you might want to do the PAIR removal. It will help with the decel popping.
    Now for the rich condition. Have you adjusted the A/F screw? Do you know what Jets are in the carb, including needle and shims or clip position?
  7. #6
    Join Date
    Jun 2008
    Location
    portland
    Age
    66
    Posts
    1,112
    Post Thanks / Like
  8. #7
    Join Date
    Oct 2010
    Location
    Lutz
    Posts
    875
    Post Thanks / Like
    Look at link 1 and watch link 2 and do the scar mod. That will fix your Rich issue. The paired valve you cant do without block off plates so order them and do it another day. A little popping isnt a big deal.
  9. #8
    Join Date
    Aug 2010
    Location
    Danville
    Posts
    122
    Post Thanks / Like
    The SCAR mod usually Richens Up a Lean Condition. With the Air Breather you have, it has probably been jetted already, andyou may or may not need to change a jet. First thing i would do is adjust the AF in a little to see what affect that has on the running, and the spark plugs. IF it continues to be rich, i would take the slide out and see what needle and shims that are in it, stock with shims or FP or DJ on some notch. Remove a shim or drop the needle lower by changeing a clip higher.
  10. #9
    Charlie D's Avatar
    Washington State Riders Group
    Oregon Riders Group
    Join Date
    Aug 2006
    Location
    seatac, Washington
    Age
    60
    Posts
    18,403
    Post Thanks / Like
    Hyper charger says to me a 65 pilot jet way to big and a 185 main jet way to small
    You should have a 58 pilot a 210 or 215 main and the clip on the needle should be 3 1/2 to 4 A/F should be around 2 turns open.
    Right now you would need to close down the A/F to under 1 turn open and you will still be rich on the low end and lean on the top end with the small main jet.
  11. #10
    Join Date
    Mar 2009
    Location
    Mobile
    Age
    71
    Posts
    1,044
    Post Thanks / Like
    Quote Originally Posted by bkjwalker84 View Post
    Do a Google search for a small application called "Cute PDF Writer" download and install it, then review the "Read Me File" on how to use it.
    Hint when you run the installation and it says it is finished, but says it needs an additional download tell it yes to proceed.
    Very neat little application for saving text or images on screen to a PDF document.
    It acts like a printer, but isn’t. It allows you to save all the data to a file for printing later.
Thread Information
Users Browsing this Thread
    1. Question Running Rich - What would you do?
      By Shadow3829 in forum Honda VTX 1300 Forums
      Last Post: 05-27-2010, 09:18 PM
    2. Question running rich?
      By kelldog in forum Honda VTX 1800 Forums
      Last Post: 04-02-2010, 11:48 AM
    3. Question Running rich
      By Sinister_Rogue in forum Honda VTX 1300 Forums
      Last Post: 07-04-2009, 05:47 PM
    4. Running too rich?
      By freemancd in forum *** The Shop ~ I NEED URGENT HELP!! ***
      Last Post: 01-10-2007, 01:44 PM
    5. Running too rich?
      By freemancd in forum Honda VTX 1800 Forums
      Last Post: 01-05-2007, 09:52 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
