oil change
Results 1 to 6 of 6
Thread: oil change
  1. #1
    Join Date
    Jan 2007
    Location
    New Jersey
    Posts
    22
    Post Thanks / Like
    oil change
    I was wondering how to change the oil and filter on a 1300 R and does anyone use synthetic oil, btw this is a great site
  2. #2
    Join Date
    Apr 2007
    Location
    Waddington
    Age
    30
    Posts
    708
    Post Thanks / Like
    Quote Originally Posted by earff View Post
    what i do is go for a short ride or just let the bike run for a few minutes gets the oil hot so it runs out easier. then i change it on the sidestand there are two(2) drain plugs under the bike i use a paint pan to slide under to catch the oil since theres not much clearance when the plugs are out and the oil is just dripping or slowly coming out sit on the bike and lean it upright to get the rest off the oil out. Then change the filter which right there near the plugs easy to see when under the bike then fill her back up and your done
  3. #3
    Join Date
    Apr 2006
    Location
    Tampa Bay
    Posts
    2,453
    Post Thanks / Like
    You can do everything with the bike on the kickstand, no jack is required. The whole process should take no more than 30 minutes, most of that time is spent waiting for the oil to drip out.
    For synthetic oil I use Mobil One Racing 4T 10-40 from Walmart ($8.23 a bottle). Purolator Pure One PL14610 is the filter I use, $6.00 at any auto parts store.
  4. Remove Advertisements
    VTX Cafe
    Advertisements
  5. #4
    Join Date
    May 2007
    Location
    Wake Forest
    Posts
    277
    Post Thanks / Like
    As the others have said, easy, no jack needed, just a pan that will fit underneath. I put a piece of 2x4 under the stand to bring it a little more level.
    I use Shell Rotella T 5w40 (blue bottle) around $16 for the 4qt at WallyMArt and the Wally Supertech filter ST 7317 (about $2.50) which got excellent reviews as far as filters go.
  6. #5
    BubbaJePH's Avatar
    BubbaJePH is offline Senior Member
    Virginia Riders Group
    Join Date
    Jan 2007
    Location
    Buckroe Beach
    Age
    59
    Posts
    1,893
    Post Thanks / Like
    1300R is no different than the other models of the 1300. 17mm socket to remove both crank case drain bolts. The stock honda filter and most others are short enough to use an end cap oil wrench. The Pro One Purlator you need a strap wrench. It is longer. The end cap will not fit as the coolant recovery can is in the way. Lube the O ring with oil on the oil filter and spin it back on 1/4 turn past hand tight. Do not use synthetic oil in a new motor. Not until you get at least 3,000 miles on the odometer. After that, it is OK to use synthetic. You may want to change the rear end oil every 6,000 miles. Get some good synthetic differential oil for the rear. I leave the bike on the kick stand and remove the top bolt from the rear end. Then, remove the bottom one. Get your pan under it to catch that oil. Once drained, I replace the bottom bolt and fill up the top opening until it is about to run out. When I refill the rear end, I stand the kick stand on a block so the bike is then upright. I use Royal Purple oil in both. 10w - 40 motor and the 75w - 95 rear. I may try the Rotella 5w - 40 for the motor on the next oil change. I need to buy crush washers for all the bolts for the next oil change. I'll have 12,000 on the next change. June, is dump and refill with fresh brake fluid as it will be two years old then.
  7. #6
    Retro Rich's Avatar
    Retro Rich is offline Just Bring It!
    Washington State Riders Group
    Join Date
    Dec 2005
    Location
    Puyallup
    Age
    46
    Posts
    2,080
    Post Thanks / Like
    Good advice on the above, especially on warming the bike up first since some forget to do that. Finding a pan with clearance is usually the toughest part (and that's not that hard) of the job. I use a cheap cat litter pan for mine.
Thread Information
Users Browsing this Thread
    1. Oil Change
      By zeke in forum Honda VTX 1300 Forums
      Last Post: 06-20-2008, 07:09 PM
    2. first oil change...
      By vtxwes in forum Honda VTX 1300 Forums
      Last Post: 05-27-2008, 09:27 AM
    3. oil change
      By yellowbeard in forum Honda VTX 1300 Forums
      Last Post: 09-16-2007, 07:26 PM
    4. First Oil Change
      By jamsorre125 in forum Honda VTX 1800 Forums
      Last Post: 08-19-2007, 06:29 PM
    5. oil change
      By Ash200cx in forum Honda VTX 1300 Forums
      Last Post: 08-03-2007, 02:44 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
