1 - 3 of 3 Posts
Replacing the front left turn signal. How does the headlight come off to plug in the long wire from the new turn signal? Does the fron part of the headlight come off?
I got it done, thanks ya'll for the help and advice. There was a bracket blocking my way to the......yes.....bottom screw in the headlight housing up front. Afterthought I should have used an offset philips but didn't have one so I took the turn signal bar off with a couple bolts and then the bracket.
Just as well as the wires were under the bracket getting squished and I replaced the turn signal housing.
1 - 3 of 3 Posts
