1 - 6 of 6 Posts
Hi, we have a 2005 vtx 1800 r, would you know if these will fit. Alos, do they have a built in oxygen sensor, or will it be compatible to have an oxygen sensor? Do you have a model number in case you are not sure if it will fit ours??
You can check bikebandit.com and compare part
numbers on the R and C models. To my knowledge,
there is no sensor on this pipe. Not sure about mod
options.
Thanks
Posted via Mobile Device
I also have stock pipes off a 2008 VTX 1800C which I nolonger need. I've upgraded to the Vance and Hines Big Shot Exhaust and no longer need. Only problem is I live in Australia and pretty sure would be expensive to send to US.
1 - 6 of 6 Posts
