1 - 2 of 2 Posts
Changed the battery last week. Started it and it ran for about 30 seconds and cut out. When I turn the key and turn the kill switch on, I hear the relay click below, but no prime from the fuel pump itself. I have searched this issue with a few responses in a Google search, but I'm looking for anyone with detailed idea of what could be going on or where to begin for the fix.
Thanks in advance!
The Dude That Rides
Check fuses to see if it is blown. If not, then check power at the fuel pump relay. If good there, then check for power at the fuel pump. You might want to click the kill switch on and off a few times to see if you have a contact problem in that as well. The fuel pump is external and is adjacent to the back of the transmission near the voltage regulator in front of the back tire. That's what I would do to start with. More folks with more knowledge will hopefully be along soon.
1 - 2 of 2 Posts
