Installed a new battery today .... here's some pics.
Takes up exactly half the space so there is room for the ECU and the flasher relay to hide.
Bike starts in a third less time. Here are some measurements I took along the way:
Starting voltage:
Old battery (Sealed Lead Acid) .. 12.5 volts
New battery .. 13.3 (straight out of the box)
Voltage Sag:
Old ... 11 volts
New ... 12.9
I had no DC ammeter to measure the differences in amperage (with respect to voltage)... but the starter does spin faster... must be the additional voltage.
Charging voltage was 13.4 at idle ... 13.9 revved up like mad. This battery can use the additional voltage above 12.5 (the old battery) so I should have 13.8 volts available whenever I start the bike. A lead acid battery simply cannot do that.
I did this to improve my cold weather starts.. which on the old battery was a "cross-your-fingers" kinda thing.
We shall see.
Starting voltage:
Voltage Sag:
Old ... 11 volts
New ... 12.9
We shall see.
