This needs to be made a Sticky - I'll make the motion, is there a seconder?
On my Hypercharger there is a black plastic fitting that the breather hose is connected to. The fitting is in the downward sloping metal bit that connects from the carb throat to the hypercharger base. And my instructions refer to plugging off the tube for the PAIR valve system, which I had removed anyway. There is also a carb vent hose that connects to another black plastic fitting in the base of the hypercharger.I just installed a hypercharger and ran into this problem. The directions for the hypercharger said to cab off that breather hose with a supplied cap and clamp. I guess this was the wrong thing to do. My question now is, can I run the bike with that hose not capped as it does nothing for the hyperchager any way. And do you just tap the seal back in with a hammer? Will it leak at all or should I get it repaired at the dealer. Thanks in advance.
There are few situations to ever go to the dealer. Whatever you do don't cap it off block it or kink it. You can mount it under the hyper charger with a little filter of its own or do what I did and take a few feet of fuel line and and run it along the top of the frame then under the seat and mount a little filter on it somewhere down there.I just installed a hypercharger and ran into this problem. The directions for the hypercharger said to cab off that breather hose with a supplied cap and clamp. I guess this was the wrong thing to do. My question now is, can I run the bike with that hose not capped as it does nothing for the hyperchager any way. And do you just tap the seal back in with a hammer? Will it leak at all or should I get it repaired at the dealer. Thanks in advance.
