Pin that comes up would bump into plate vs into space allowed if bars not moved far enough.tried in in the fork locks. It would turn but not lock the forks. Is there a trick?
Yeah, bags render the helmet lock pretty worthless. You can remove the helmet lock if you want. Some do this because it can rattle. Others do it so that they can relocate it.Yep, wiggling the handlebars and key got them locked. As far as the helmet lock I do have saddlebags so no need to look any more.
That only says - he doesn't know what he's doing.guy made the first one, it didn't work
Is this 6 digit code the same as the one that is on the ignition switch? I spoke with a local locksmith about getting some new keys made, since I don't have an original key, and he told me to bring in the ignition switch and he can make a new set of keys from the code on the switch.The key code for ALL VTX's, both 1300's & 1800's is stamped into the bottom of the gas cap. Simply open the cap and find the 6 character alpha-numeric code stamped there. The key code will be the last 3 digits, either A, B, C, or D 00-99 as A12, B12, C12, or D12 (the 12 could be anything from 00 thru 99).
There are 2 keyways used (commonly called Left and Right by anybody but a real locksmith, as mentioned above). The determining factor as to which code uses which key is VERY simple. A00-A99 and B00-B99 use HD74 and C00-C99 and D00-D99 use HD75.
Hope this helps somebody.
