1 - 2 of 2 Posts
So
I’m on the very tight budget.want some noise out the rear though..decided to remove baffles and upgrade intake and rejet ..thinking my motor would be fine..
Absolutely. Rejetting is the key. Do this AFTER you make the other changes. While you are working on it, do the pair mod using dimpled block off plates and install Glen's permanent A/F screw. When you rejet, use ONLY the Factory Pro jet kit.
1 - 2 of 2 Posts
