1 - 11 of 11 Posts
I've got beetle bags, which I love, but I hated the turn signals. They are tough to see and the amber lenses are just ugly. Solution, find the clear lens replacement light assembly and convert it to LEDs. I spent the better part of today starting the process, after learning and practicing with LEDs. My thought is to have both a red running light and the amber turn signals.
After receiving the replacement light assemblies ($25 ebay) I spent nearly two hours separating the lens from the assembly. My advice if you attempt this is go very slow and be patient. It took nearly an hour for me to get the first 45 minutes for the second.
I ordered all the LEDs (both red and orange/amber) and the resistors ($25 ebay again).
I had decided to use plexiglass as the led mount. After an hour of marking and drilling I ended up with the clear mounts.
I inserted the Red LEDs in the pattern I had laid out.
And soldered as I went Another 2 hours slips by but I finished the pattern. There are 24 Red LEDs for this configuration
Next will be the amber/orange turn signals. which will be around 50 per side.
I got a start on them but realized I was supposed to have the old counter tops removed and the dry wall fixed before they deliver the new one tomorrow. The wife will not be pleased :nono: I guess it will be a late night...
Beetle bag tail light mod - completed
Well finally finished the tail light mod on my beetle bags. As mentioned earlier, never liked the amber lenses and also my turn signals were not very bright. So I decided to make my own.
New lights installed.
New running lights:
New turn signals:
A few things I learned:
1) If you add LED turn signals, get the plug and play flasher designed to operate any light regardless of resistance. I found one for $20-$25 and have seen them for even less. You don't need to add the resistors to "fool" the stock relay.
2) working with LEDs is not difficult. Just find the LED web sites that tell you what resistors you need and Ebay them!
3) Don't touch the soldering iron when it's on. I have two new scars to prove it is a bad idea.
If anyone is interested in trying something like this, I will be happy to help/answer questions as much as I can.:cheers:
New running lights:
New turn signals:
Nice job! oh, and i totally hear you about touching the soldering iron:mad:
thanks for sharing with the pics.. Bry
1 - 11 of 11 Posts
