Okay folks I can't get my bike started now. I'll give brief overview then get to current (2004 VTX1300s).
I did a mod on my stock exhaust last month:
•Gutted almost everything out of stock mufflers, left one chamber, and one baffle in each, and shortened each muffler by ~4 inches. (see pics).
2 weeks ago began using A LOT of fuel so:
•Pulled carb enough to clean float bowls etc.
• Did PAIR mod with Goheen dimpled plates, and installed airbox rubber plug.
•Decapped airbox
•Installed Glen's permanent A/F screw
•Replaced 55 main jet with 58
•Replaced 195 pilot jet with 198
(These are not Factory Pro, they're from 6Sigma Cycles because factory pro was out of stock, did NOT come with new needle)
•Stock needle is still installed, but NOT shimmed
•Reassembled.
•Set A/F screw 2 turns out
•Idle screw is 1 turn out
Before attempting to start:
Problem #1: The entire fuel switch (pet cock?) has to be turned slightly in toward engine to get the fuel hose reattached. NEVER had this issue before. (see pics)
Problem #2: Battery dead. Recharged overnight.
Problem #3:
WILL NOT TURN OVER AT ALL, EVEN AT FULL CHOKE
Upon reassembly I checked everything. All vacuum/fuel hoses are clean and attached properly. Cleaned airbox, and filter is still good.
I used the 198 pilot because I didn't fully gut my mufflers. They are 4 inches shorter, and still have one chamber and one baffle. (See pics)
Questions:
•Is the pilot jet the wrong size? I have a 200, 202, 205 & 208 I can replace the 198 with.
•Do I need to shim the needle? I have plenty of those.
•What the hell is going on with the petcock?
This bike is my only transportation. I'm disabled, and out of money now. What did I just mess up?
Help me,
Moose
[IMG alt="papamoose1977"]https://www.vtxcafe.com/d1/avatars/m/129/129305.jpg?1656090491[/IMG]
papamoose1977
·Registered
UPDATE:
Took off breather cover, put my hand over intake, sucks like a hoover. Took my hand off and hit start, it fired twice. Repeated process, fired twice. So, maybe not enough air??? Inside valve pushes up and down freely. So that's good.
Vinish
·Super Moderator replied:
I recommend that you post all of this in an open thread - that is, one viewable by everyone. You will get better answers if others have input rather than just me.
You say, "WILL NOT FIRE AT ALL, EVEN AT FULL CHOKE" but I am unclear on what this means. I will assume it means that the starter motor engages and turns the engine but the engine will not stay running. In order to run, a bike needs four things:
1) air
2) fuel
3) spark
4) compression
The cause of not starting are almost never #1 or #4, especially in a case like yours where the bike would run before you did all the work.
Start by checking for spark on all four plugs. To do this, first put the bike in neutral and verify that it is in neutral. Remove each plug, put the plug back into its boot - making contact with the connector. Then hold the metal threads or the metal hexagonal portions next to the threads against some part of the engine. Dim the lights in the garage, and try to start the bike. You should see a dim blue spark at the electrode of each plug.
Next, look at all the work you did. Are all the hoses properly connected? It sounds like something is wrong from the positioning you describe of the fuel hose leading to the petcock after your work. Verify that you have fuel getting to the carb. To do this, after trying to start the bike, unscrew the float bowl drain screw and see if fuel comes out the drain port. You could also spray starter fluid into the air intake throat of the carb while trying to start the bike. If the bike will run for a few seconds on the starter fluid spray, you know the problem is not spark and is fuel.
G'day,
Vinish
papamoose1977 replied:
•It has spark.
•It IS a fuel issue.
The jet that sprays the fuel when you twist the throttle no longer sprays anything. I don't know how the hell that happened. It worked fine before I removed the carb because that was the FIRST THING I checked before pulling the carb off the intake.
•When I put my hand over the intake and hit the start, it sucks like a hoover and will fire a couple times but not run. There is fuel in the intake afterward though and on my hand. But if I hit start without my hand over the intake, no fuel. So...it's indeed no longer getting fuel...obvious also because I can't physically see it spraying out now.
•I cleaned everything REALLY GOOD before reassembly, and sprayed carb cleaner on it all one last time before reassembling. I checked every connection too. All was good except the petcock having to be turned slightly for some reason to get the fuel hose reattached.
•That fuel hose from the petcock shouldn't be blocked, but I have new hose and will go ahead and replace that first, which won't hurt to do anyway.
•I've already disassembled it all AGAIN.
•I'm about head to Home Depot for new bowl screws and screws for the diaphragm cover. I stripped the heads as I knew I would. They were super soft and wasn't hard to do.
SOMEONE PLEASE DIRECT ME, OR POINT OUT SOMETHING I MISSED!!!
I'll check back here when I get to the store, and then again when I get home.
Thanks again,
Moose
•Decapped airbox
•Reassembled.
Problem #3:
Questions:
Help me,
Moose
papamoose1977
·Registered
UPDATE:
Vinish
1) air
2) fuel
3) spark
4) compression
G'day,
Vinish
•It has spark.
Thanks again,
Moose
