'07 VTX 1800R: neither the front brake lever nor the rear brake pedal activate the brake light. Bulb is good, wires connected. I have the "triple whammy" run-turn-brake system installed. Turn signals/running lights work fine.
thanks in advance
Doc
Have you actually tried a brand new bulb...They can look fine, but have a small break in the filament and not work...
got it fixed... thanks... spring load thingie (I'm a doctor not a mechanic) from foot pedal was hung up... thanks!
Does the front brake lever work the light now??...Those are two separate systems and having the spring for the foot pedal shouldn't keep the front lever from lighting the light (to my knowledge)...Might still have an issue up front with the wiring going into the front brake light switch...
