1 - 14 of 14 Posts
bought new brake pads and started the change, old ones are still good bike has 38K. Is this normal for these bikes
The Wanderer
Yes depending on your riding style they can last a long time. You can also check them before you pull them by looking at them with a flashligt and plumbers inspection mirror, just make sure to look at all the pads.
El Chupacabra Lives!
Aww Marty, you know the inside rear pad would never wear down to dust while leaving the one you can see almost new. ;)
Just did my rear pads at 27K.... they could have gone 5k longer, I'm sure, but I changed them anyway...the original fronts are still there and are thick... was amazed to see that.
I've gone through 2 sets of rear pads and my front pads still look new.
Yall who changed rear pads only, are yall heavy on the rear brakes?
For casual stops I usually go with about 75% on the rear brake, we ride 2up a lot so I tend to use the rear more to help keep her from sliding forward while stopping.
IBA #37750
I just changed my front pads last week. They had 48K on them.
I tend to use more rear brake than front, especially at very slow speeds. Usually touch the front brake only when I'm stopped.
Just about never use front brake,unless its a panic stop.Old school rear brake.:coffee:
I was just curious. Of course the braking is "suppose to be" 80% front and 20% rear, but I didn't know how religious folks followed it.
any particular manuf recommended pads? Sintered, Semi Metallic, Kevlar? OEM? Organic or no? does it really matter?
I have Organic brake pads by EBC both front and rear on my VTX. The Sintered pads will eat up your rotor.
1 - 14 of 14 Posts
