1 - 6 of 6 Posts
If you have a stock needle you will need to add some shin washers #4 is the size and you can get at an Ace Hardware.
Or if you want even better just order a Factory Pro stage 3 jet kit
The 195 is the stock main. It's not big enough to handle all that air your letting into the carb. I put a spike in take on mine and I had to put a Factory Pro stage 3 kit in. I am using the 210 main, with the #58 pilot and I have the "E" clip on the 4th notch with another half shim under that. I used a #4 washer measuring 0.020" thick. Factory Pro is the only kit that works on these bikes.
Been about two years since I installed spike type breathers for anyone but shimming always worked. That was with the 195 stockers. The ones with the 185s I just replaced the main with a FP jet.
Always did the trick either way.
Wren
1 - 6 of 6 Posts
