1 - 20 of 22 Posts
· PEOPLE CALL ME GERSTY
i have a 2007 c when i hit bumps there is a clanking in the back of the bike somewhere i thought it was the license plate bracket but it is tight any one have or had this i would appreciate any info
thanks GERSTY OUT
I have the same clank (or clunk). Started hearing it in the front too. I think it's the suspension (best I can tell). Jury is out until I make the switch to the progressive shocks and springs - which may be soon.
thanks GERSTY OUT
Hi :patriot: this clanking is the BRAKE CALIPER.:choppersm
Discussion Starter · #8 ·
thanks for all the replies is there anything to remedy this or am i just going to have to deal with it
What setting are your rear shocks at. Try upping it one setting and see what happens.
Discussion Starter · #10 ·
the shocks are set at factory 2 should i go up to 3
IMO its worth a try. I'm 275 and ride at 4. I'm at 4 only because I'm too lazy to keep switching when I ride 2-up. I tried the setting at 2 for a while but I kept bottoming out. 3 does work for me. I say try it and see what happens. You can always change it back if you need (or want) to.
Clanging in rear?
I just purchased a new 05 1800R and have the same noise. I asked the dealer about it when I was unable to locate it and he said probably play in the driven't shaft. That just sent me back to searching as I've had shaft drives before that didn't have this problem. If you locate the cause please post it, on my bike it's quite loud and distinct but doesn't do it on all bumps.
Discussion Starter · #13 ·
camaroz28pr says that the clanking is from the rear brake caliper, i went out and tried to remedy this but i guess there is nothing you can do about it i am about to add hk sideburners so hopefully i wont be able to hear it for very much longer
GERSTY OUT
Thanks for the other ideas. I've been gone for a couple of days but plan to spend most of fathers day putting around on my bike. I'll try to check some of these out. I did already check the helmet lock though, I wrapped it tight with electrical tape didn't help.
Meta355 It doesnt seem to clunk when brakes are applied it seems to be bumps, I first noticed it idleing over some speed bumps. The brake caliper does have some some slop if I grab it and try to shake it. Could be the problem but I'm going to try to check the shocks and the kickstand idea
1 - 20 of 22 Posts
