1 - 8 of 8 Posts
:cheers: Instaled all clear lens today, what a big chang to look, front with HDL light bar is a big plus. Put bike in garage and shut door , brake light does not have a real red color to it , will have to look for differant bulb.Have ssen other post with same thoughts.Still cant ride do to broken clavicle bone, maybe next wwek i wiil sneke out when noones watching.
Go for LED's. You won't regret it.
VERY sorry to hear about your clavicle! Been there, done that! I know your pain. Mine was so bad that I actually had to get the end of it ground off.
· The FASTEST color!!!!!!!!
Do you have any more info on the LEDs you used?
SURE! Here you go.
My tail light LED
http://www.radiantz.com/c14.html
My preferred turn signal LED's. WAY brighter than stock bulbs. Don't let their looks fool you. At 3 watts, these are THE brightest LED's you will find!
http://www.superbrightleds.com/specs/115x-xLX3.htm
Misc 12 volt LED's for turn, brake and tail lights. My fav flasher is also at the botom of this page.
http://www.superbrightleds.com/tail-brake-turn.html
Skip the load equalizers. I never use them. Just replace your stock flasher relay with a cheap electronic one that can also do LED's. Available at Custom Dynamics and probably just about everywhere that sells LED turn signals. They are plug and play. Just unplug your old flasher relay (under the right side cover) and plug in the new one. Some flashers (stock ones) do not work properly with LED's, some ONLY work with LED's, some will work properly with ANY combination of incandescent and LED bulbs.
To help get you looking in the right direction:
http://www.superbrightleds.com/flashers.htm
http://www.customdynamics.com/trick_flasher.htm#Standard_DOT_Flasher
Hope this works for you.
Cheers!
SURE! Here you go.
My tail light LED
Cheers!
Thanks Goldsmith, she's probably the best 20 lb. package we've ever had!
Thanks HotX, that's exactly what I wanted!
1 - 8 of 8 Posts
