Now that I have the Kuryakyn 4604 Run Turn Brake system installed, I am ready to convert the front and rear turn signal and brake light lamps to LED. So, can you fellows recommend a high quality replacement white LED lamp for the front and rear turn signal lamp sockets and one for the brake lamp socket on the VTX 1300C? The Kuryakyn RTB came with a single load equalizer and an additional connector for a second one if necessary so I'm good there. Also I installed the Kuryakyn red rear lenses so white LEDs are good all around. Suggestions? Thanks in advance for everyone's time.
I will probably also install an LED headlight and I think the recommendation in this forum is the Daymaker headlight is that right? Or is there a direct drop in LED for the headlight that is of good quality and bright? I think bill_rides had a good one he recommended.
Barry
Barry
