OK, I have read through the various threads and tried to test all that I could. My fan is not coming on when it should, here is what I have tried..
Checked the cooling level, all good
Removed the powdercoat / sanded the ground and reseated it.
Jumpered the fan ground to a known good ground,
Pulled the wiring harness on the switch and jumpered from the bottom of the switch to a good ground... none of the above worked..
I then placed my test wire IN the wiring harness that connects to the switch, then the other end to a good ground and the fan turned on.
So I think that it is a ground issue, but not sure. Could it be a grounding issue further up on the harness? I read that it connects somewhere under the tank?
Thank you in advance for your help
