As you can see by the original scoop, it is made for a bike without a radiator. So I took some measurements and cut out a little off the top center. Just enough so the scoop will sit better on the frame, snug against the radiator. It will not interfere with the radiator, and as you can see in the finish pics, there was enough from for my Irate customs radiator cover.
I drilled a couple of holes on the bottom sides of the scoop, so I can tie wrap the scoop to the lower frame rails. (The following couple of Pics are original moc-up on my C2. The 1300 will be the same) I also tie wrapped the top portion of the scoop, just for moc-up.
