Are you running the stock s fender? it will fit but I think you will need the rotor adapter if you look in the forum they is a thread on these and a lot of great informationDoes a 2004 VTX1300C wheel bolt straight up to a 2003 VTX1300S. Sorry, for the silly question. I think it would, but?
It all depends on the tire you select. 19" C front wheel uses a lower profile tire. If you increased the wheel and had the same amount of sidewall, then yeah, but you increase the wheel size and decrease the sidewall. This nets the same tire diameter.It's stock S fenders front and back. 19" won't rub fender from bumping up from 17"?
The S and R models have the same fender. I have an R, here is a picture of my R front wheel:Would the skinnier tire look funny on the S? I found an R wheel mag that is same size tire as S.
