Hi All. While I have a 1300C, this question is general for clutches and concerns my son's Shadow 750.
Some TLDR notes:
We bought the bike, and the clutch lever would not engage/release the clutch until about 80% of lever release. We did a few adjustments to it for better lever feel where it would engage/release the clutch about 50-60% of lever travel.
We then changed the oil with motorcycle oil (Valvoline 4-stroke 10W-40 with claimed "Excellent We Clutch Protection"), a K&N filter, refilled to a proper level, and took the bike for a test ride.
About 3 miles into the ride, the clutch started slipping and then not engaging at all. I was able to do some adjustments on the fly to get it to where it would engage just slightly enough to get the bike to limp home. I could only have the throttle at about maybe 10%, otherwise it would just slip and rev the engine without accelerating. We got it home, though, but not without having to ride it a few miles in that slipping condition (which I knew was probably destroying the clutch worse, but it had to be done).
So, my assumption is that we will be getting new clutch plates and installing them. My question is, does it sound like the clutch was already basically bad when we purchased the bike? It literally probably has about 20 miles on it since we bought it, and the first 10 or so miles and test drives went well, other than the exceptionally long clutch-lever travel. The, suddenly after the oil change, the clutch failed on us about 3-4 miles into the ride.
Thanks for any and all help, I'm just trying to figure out if clutch was already going bad when we bought it because of the crazy lever travel, and do you have any recommendations to where I should buy the new clutch kit from? All help is greatly appreciated! This my son's first bike, and yesterday was his first legal ride on it with a license, and this happens.
Some TLDR notes:
- Extremely long clutch-lever travel when purchased a few weeks ago, but it test rode fine and rode the 8 or so miles home fine with no problems.
- Bike sat for a few weeks, then we did some basic clutch-lever adjustments and changed the oil with appropriate motorcycle oil and K&N filter.
- Next test ride after oil change, clutch starts slipping about 3 miles into ride, then only moves the bike at 10% throttle...anything above that just send the engine into free revving as if the clutch lever were pulled in. Bike moved very slowly with clutch barely engage at all.
- I checked oil level after returning...level was perfect, but it definitely smelled like burnt material (I assume clutch).
- Assumption is that we need to replace clutch...any recommendations for clutch kits?
