1 - 3 of 3 Posts
For those of you who have swapped or replaced final drives does the swing arm get removed? Or how do you get the shaft into the u joint? Is it just slip in before buttoning up the new final drive? I have Clymer's manual but it's not clear to me. My Honda service manual is somewhere in storage since my last move. Tire is off and I am ready to pull old drive and replace. Also is the flange drive bearing real tight in the race? My old one spins fine and shows lots of moly paste still. I am replacing final and shaft with a very low mileage 1800 FD. I'd like to get responses from folks who have actually swapped drives out.
thanks,
Xrider57r
VTX 1800R 2002 136,400 mles
GL 1100I. Which will be nekkid project bike.
WildBikers.com Owner
NOPE - Does not!
Take Off Wheel - Brakes
Loosen 4 Bolts
Slip it out, New one back in (Might have to finagle a bit to align splines).
Use your MOLY Paste liberally.
Tighten back up and reinstall wheel,
1 Hour Job Tops.
Thanks, yes, I overnight end the new Honda paste. My tube of Honda Moly 60. I got when I first bought the bike got stolen a few years ago out of the saddle bags with some tools. Local NAPA had nothing even close.
with luck I'll be at the Oyster Run Sunday.
Xrider57r
1 - 3 of 3 Posts
