Went ahead and pulled tank off and done the scar carb mod.Already had cobra slashdowns installed.Drilled holes in stock air box used the extra cover BB sent me also +1 BB tried your idea on printing the x from x-cessories site that worked out good.Got it cut out but using what i have a high speed cut out tool sorta like a dremel on steroids .Gets things a little hot and ripples chrome right along the cut line to bad i don't have a water laser machine just sitting around ha.Any way added 2 #4 washers trimed tit under small spring and cut large spring down to 6" sorry scar couldn't make my self cut it 5 1/16
Looked like it would be a bitch to get to pilot screw (bracket for stock air box in the way)So i didn't mess with it at all .Put it all back together and went for a ride no flat spots no bog idles good checked plugs ok.(May get a dyno run on it 75 bucks for hp, torque and air fuel mix 50 for hp and torque.(Is this price about right or should i look around there close 20 miles and said they do 3 runs)
