1 - 8 of 8 Posts
My left front and rear driving lights on turn signals went out. Blinkers work just fine. Changed out turn signal unit on handlebar with new unit. All wires connected in headlight bucket. Still does not work. Turn signal indicator constant on. Not sure where to look for issue.
You should provide info on the model and year.
1300 and 1800 1st Gen have a TS switch that controls the TS/DRL.
1800 2nd Gen has a TS controller.
Any mods done to the TS??? Leds?? Add-on rear TS/running light converter??
Front run light goes Off when TS activated for whatever direction you select.
Dual filament bulb in the front TS/Run light.
Rear TS has a single filament bulb on the unit.
Single TS indicator bulb is bridged across the Right and left TS wires.
Do you have the correct bulbs installed?
Or installed the correct way. Some bulb pins are not 180* across from each other, and some are slightly higher on the base than the one on the other side.
1 - 8 of 8 Posts
