NOTE: This issue was QUICKLY solved with the expert help of several totally awesome experts on this forum :mosh: Thanks a ton guys!
ANOTHER NOTE: If you need a starter solenoid (relay) or a starter motor, use the resources at the end of this thread to save big money
2003 1800. So here it is... For the last little bit, my starter has been turning over really slow. It would crank once, pause and then start pretty normal. So today, it wouldn't start. It turned over slowly a few times, and then refused to turn over again. I took the battery to autozone to have it checked, and it appeared to be good (no amperage test. only voltage). They also charged it all the way. after I put the battery back in and torqued the screws down with a wrench, there was no change. After researching, I learned that the solenoid was a likely culprit, and also that some folks had noticed an improvement by using a universal automotive solenoid, which is practically plug and play... I put in an automotive solenoid, and the problem stayed the same... except the beefier solenoid got stuck and the starter kept trying even with the key off. I had to disconnect the battery cable to stop the starter from slowly turning over... furthermore I could hear a funny sizzling sound for about 30 seconds after I disconnected the battery cable.
The bike has a PCIII, Honda Driving Lights, self-canceling signals and two 12 volt outlets
I have only had this bike for two weeks!
Anyone got some advice??
