2002 VTX 1800C
turn signal problems:
activate R or L ......both front TS flash (led) ....the flasher light on the panel
flashes very dim.......the rear has the intergrated light to which the amber and
red lights bleed together... I have isolated the front and the back and used direct power on each.they work fine.its just when they are put together all hell
breaks loose......i have the resistor and the led flasher...still the same problem
I rewired the TS from plug near the main fuse,back to the rear lights...
the origin of this ordeal.when i bought the bike,it had a turn signal light bar
under the headlight.the lights were bleeding a bit,my brother stated "its hard
to see your signal from afar".so I removed the led light bar(from HD)and installed led signals on the forks...and here i am today.hope for the best and prepare for the worst.I think I may have to rewire the front.just need some help on this one......:hmm2:
