I'm a new member with a new 2008 - 1800f.....seems to have an engine vibration around 2000 rpm......is this normal?
thanks for any assistance
all v twins vibrate to some degree, they do not have the smoothness of an inline motor. That being said, the 1800 motor uses counter balance on its split pin crankshaft and does not vibrate as much as other v twins normally. Is the RPM steady or is one cylinder missing?
F rider
What gear are you in and what speed are you going? Also, I have an F, and I am pretty sure the factory tach reads a little high. I say that because I have sewn mine read over 6000 rpm, and from what I understand the rev limited on these bikes kicks in at 5850. Also, remember that this thing has HUGE pistons, and is gonna vibrate a little.
Sent from my HERO200 using Tapatalk
engine vibration in any gear 2000 rpm or slower......most noticable in higher gears when pulling a load
I suspect you are lugging it - to low a gear. Let it sing to 3500-4000 before shifting. The damn thing has so much power we get lazy and shift too soon.
Welcome from Tennessee and wishing you a nice day. :patriot:
