1 - 1 of 1 Posts
Engine failed to start (never happened before) and FI asserted code 19.
I disconnected the two-pin Ignition Pulse Generator connector and inspected the contacts within.
On the pulse generator side the socket contacts were a dark color from the bright brass that the are. Also, when i inserted a mating blade contact, there was no friction to hold them tight.
So, I replaced the contacts (thanks Cycle Terminal for having them. F .110 and M .110) and the bike fired right up running smoothly.
Note: One will need the contact extraction tool and the contacts require a special crimper, but those tools are worth having since just about all contacts use this crimp style.
I saved big bucks not buying a complete stator assembly to get the pulse generator. Hope this helps anyone experiencing the same thing.
1 - 1 of 1 Posts
