1 - 20 of 93 Posts
Cafe Founder & VTX lover
Here is how I changed my drab boring silver engine to a sweet looking black and chrome one.
First, plan on spending some time on this project, maybe 15-30 hours. I have read about people doing it in 2 hours...I have no idea how anyone could do this job in 2 hours, I spent around 20 myself.
You will need:
- Scuff pad
- Engine paint. I used VHT 500 degree paint, remember if you use 1500 degree paint the ending need to be ran shortly after so plan accordingly.
- Masking tape (painters tape)
- 2 hand files
-Sandpaper (220, 400, 600, 800, 1000, 1500, 2000) is what I used. I had the 3M polishing kit, I used that and a sanding block to do most of the sanding.
- Dremel 520 Polishing Wheel (love it!)
- Dremel Finishing Abrasive Buffs (great for the corners ner the plugs)
- Pinstripe tape (if you choose to use it)
- Vasoline (if you choose to use it)
1) Remove as much of the chrome, covers, pipes, switch etc. The more you leave on the more you have to work around. Tape up any chrome near where you will be working, I doubled taped just incase the file slipped and struck the chrome. I also place cloth in both exhaust ports and covered with tape to preven any shaving from entering the engine.
2) Use the scuff pad to scuff the silver paint as much as possible. This does take a while but do it. I took a piece and folded it over a ruler and ran that between the fins.
3) Clean engine off. Wipe the entire engine down with a good prep cleaner and blow off everythingwhen done. Just make sure you get all the cleaner off the engine.
4) Now the fun starts! Get the hand file, a six pack or two and start filing the edges off the fins. Try and file across a few fins at a time when possible to get the even.
5) After all the fins are filed flat and to your liking time to start sanding. I started with a dry 220 paper, after the 220 all other sanding was done wet and I used WD40 and the wetting agent. This again takes a ton of time.
*Safety note - when you had the 6 pack or two stop sanding/filing and go tape up something...lol
6) Once all the fins are to your liking start cleaning the engine again, vacuum all the shavings off, blow out all the crackes, and just make sure it's clean!!
7) Now you must make a choice. Time to paint, there are several different ways to do this and here are the choices that I know of:
  • Use vasoline and a Q-Tip and cover the fin edges and bolt heads with vasoline prior to painting. After painting wipe the vasoline off to expose your fins.
  • Get small auto pinstripe take and carefully cover the fin edges with it prior to paining, pain, then remove the tape.
  • Paint over everything, after painting then go back and sand the paint off the fins, repolish as needed.
I did the third, it still was a PITA because I allowed the paint to dry...got busy and came back a few days later. I wish I had started sanding a few hours after painting.
8) Complete taping off everything you can possibly see. Remember there are gaps here and there, make sure you have them all covered.
9) Start painting, keep the can moving, and apply several coats.
Depending on the method you choose in #7 proceed accordingly. I finished mine off with Never-Dull and was done. While I did not use the vasoline on the bolt heads I didn't on the fins.
Here is the finished photo:
Hope this help, I maye have missed something if so sorry...have fun!
VERY NICE WORK!!! I've been considering painting my mill deep red to match my tank and fenders and then following your leads on the fins. Well done.
great job, This might become a winter project for me, if we don't get any snow. again, nice job and thanx for all the tips
it's not easy being easy
great job. how do you remove the bracket that holds the air filter box on?
Innit for the long haul..
Great looking paint job! When I read your procedure, it sounded like something I may want to try - my bike is silver and I thought the engine would look good with black and chrome...er...billet!
Gotta question, though, will the paint cause the engine to overheat? Read an article where someone painted an engine and is experiencing over heating. It was not a Honda.
Thx!
Monk
Very Very cool can you e mail these in instructions to me so i dont loose them i would be realy greatfull i want to do this to my 1800s. Do you know were to get colored high temp paint i have an 02 in the pearl candy orange
and i would love to do this. [email protected] Thanks
Polishing fins
I want to do this mod, but I want to try something in reverse. Clean and paint the engine first, then file the fins and polish. I contacted NAPA and they have a clear high temp no gloss that can be used after polishing the fins. Hopefully the clear does not yellow.
Love the safety note.
Yup, but I think he forgot to observe it...
Rick1800R said:
Get small auto pinstripe take and carefully cover the fin edges with it prior to paining, pain, then remove the tape...
There was a lotta pain'n going on! LOL!
Great job & write up.
Go Boilers!!
Question...what is the purpose of filing the fins? Is it to just expose the raw metal? If so, wouldn't one of those small woodworking sanders be good for this? Something like this ... http://www.garrettwade.com/jump.jsp?itemID=111229&itemType=PRODUCT This would allow you to hit several rows of fins at once to ensure you sand them evenly.
I'm thinking that painting the entire engine black and then hitting the edge of the fins with a sander to remove the black paint and the OEM paint would be the route to go. Then apply clear coat at the end.
starting this project tonight , looking to spread it out throughout the week thanks for the ideas , hope it turns out good !
Administrator
:D Ah, now we see the light. That is what's really wrong with your arm.
Dr. Dave says it's sander's elbow.
I take it your a mason. I am as well pastr master of my lodge Paul Revere#162 Denver CO in 1985 Just wanted to say HI brother and nice bike keep the rubber side down
1 - 20 of 93 Posts
