1 - 20 of 36 Posts
First of all forgive me all the writing. I read through quite a few threads on the vtxcafé and the vtxoa site, and asked several questions before I was able to understand the problem and what could be a possible fix. Here is a link that I read through to understand what was going on and why we are having this issue: Its long and has some very detailed information, excellent read:
bareass choppers flange bearing write up link
So after all this, I thought that I’d do a write up to help other guys out there like me who were lost at what flange bearings were and where they went and how to change them. At least this would be a starting point…..
How do you if the flange bearings are bad:
With the rear wheel off, visually inspect the bearings. Do they look damaged or the seal is broken. If they look fine, then turn the bearings in the flange with your finger. If they are turn smoothly, then they are fine. However, if they turn with any amount of roughness or you can feel the ball rubbing and turning, then they are bad and need replacement.
Removing Rear Tire:
The steps below may not be what the book says, but they work just fine for me…..
Raise the bike & tie down bike.
Loosen the “stopper pin bolt” for the rear caliper and pull back as far as possible (stops at the pipes in my case)
Remove the first hose clamp bolt upstream of the rear caliper.
Loosen and remove the axle nut.
Pull the axle out and collar falls out.
Pull the caliper up and out and support it (I usually just it on a towel placed over my pipes).
Remove the rear wheel by moving it towards the right to disengage it from the final drive and off.
Removing the Flange A and B:
Refer to page 14-7 of the service manual for the rear wheel assembly picture/diagram. There isn’t a whole bunch of info about the flange (known in the service book as “final drive flange A”) in the service manual since Honda sells it’s as a unit (flange + bearings).
Since you are going to be removing the flange to change the bearings, you might as well remove “flange B” and clean out the area that holds the rubber damper to help increase the life of those dampers.
Lay a clean towel or cloth down so that it prevents and damage to the rear rotor and lay the tire on its rotor side down on that towel.
Remove the 5 lug nuts that hold the flange onto the wheel.
Remove flange A by prying it upwards gently from the opposite sides using two flat head screw drivers to work it up and out of the lugs.
Remove the stopper ring using ring pliers
Grabbing the lugs by the fingers, pull on flange B and work it out by gently rocking it back and forth.
Remove the rubber dampers.
Cleaning:
Remove the rubber O rings from the Flange A and the wheel hub. Clean them using a dry clean rag and store them in a safe place.
Clean the rubber dampers with dishwasher soap and a stiff bristle brush. Make sure you don’t damage the dampers.
To clean up the next two items, I used a clean rag and some paint thinner (that is what I had handy).
Clean out the hub (the area behind flange B) including the notch from where the rubber O ring was removed and the slot for the stopper ring.
Clean up Flange B and the stopper ring.
Flange (“Flange A”) Bearing Removal, Findings and Fix:
Insert a “blind hole puller” through the sleeve from the back side of the flange and tighten up until the attachment clamps open and are snug against the inside of the sleeve.
Grasp the handle of the puller and raise it so that the flange is hanging off the ground or table surface by an 1” or so.
Slide the hammer up and down a few time and the flange will fall off.
Turn the flange over and use a socket the fits over the inner bearing race an using a hammer, knock out the two bearings inside the flange bore.
Now clean up the flange
This is where I went to a local machine shop and the guy there put the flange into a machine and he then gave me exact opening diameter of the bore (where the bearings go into) at the top, middle and bottom. The following is what I found (opening is about 1" deep -- Some of you might have read about this in the other thread when I was asking for help with the flange):
inside dia at top of flange opening = 1.6516"
inside dia at mid height of flange opening = 1.6509"
inside dia at bottom of flange opening = 1.6504"
the outside bearing dimension that is going to be placed inside of that hole is 1.6535". There are two bearings that will go into this opening.
From what I saw in the threads either used a flap wheel sander inside the opening to touch it up or took it to a machine shop to open up the bore. The correct way to do it would be to take it to a machine shop.
Take flange to a machine shop to open up the bore so that you could get a 0.0005” to 0.001” press fit. Make sure that the sleeve or “distant collar” has a press fit of 0.0005”. Mine was fine.
Lack of patience to look around and had a load of other things to do and was looking for the cheapest way out since I have been on a budget since the beginning of this year, I chose the flap wheel way and called it a day. However, when I did this, the bearing was clicking, which means that the bore was too still too tight! I ended up damaging the bearing.
So I ended up finding a local machine shop that charged me $80 do open up the flange and press fit the bearings into the flange. Might as well fix the problem correctly the first time. Less down time for the bike.
Installing the bearings + sleeve into flange:
I cleaned up the outer side of the sleeve with 3000 grit paper to remove some rust marks that circled the outside.
I had the machine shop press in the sleeve and the bearings into the flange, but if you are doing it yourself, install the bearings onto the sleeve using a socket that fits just exactly over the inner race. You don’t want to load the bearings, so make sure the socket does not overhang the inner bearing race.
For an easier fit, put the bearing + sleeve assembly into the freezer overnight. Either heat up the flange in an oven or leaving it out in the sun in the morning and by the afternoon, it will be very hot!
Using a bearing & race installer, install the assembly into the flange.
Installing Flange back onto the wheel:
Install the rubber dampers
Apply moly paste into the O ring groove. Coat the O rings with moly paste and install into the groove.
Install the flange B into the wheel making sure it sets in properly
Install the stopper ring.
Install the flange (flange A) over the lugs and install the nuts to 65 lbs.ft torqe
Apply moly paste into the O ring groove in the flange. Coat the O rings with moly paste and install into the groove.
Apply moly paste to the splines of the flange and the gear case and you ready to install the tire back on.
Well that is it. I would love to have you guys add what you all did or have suggestions or comments that would help others. Please feel free to correct me where I may have gone wrong…..
I contacted JON'SVTX1800C about the swap out for the flange and will be doing this a soon as I get a chance.
Was just curious.... is this a permanent fix, or can the bearings still crap the bed on us again after this is done? Does this just make it easier to replace the bearings later and extend the life of the bearings a little longer? :hmm2:
Discussion Starter · #6 ·
You did a good job, there is also a guy on the OA that bores them and does a core charge that is refunded when you return the undersize one.
thanks charlie. you are right, the guy is Jon'sVTX1800c. he charges $150 for the rebuilt flange and if your core is good, he will return you $65. he uses Koyo bearings that are pre lubed.
i was going to go that route first, then i started reading and asking q's and then i went to town on my flange with the flap wheel sander, so then i just basically gave up and started calling all machine shops. there was a guy who wasnt going to charge me anything, but he said he cant guarantee any results, so kinda scared me, so i went with this other guy who was closer to me..
Honda had their head up their azz on this one for sure, how can they explain a tappered bore like that? Plain stupid......:hmm2:
tell me about it. there is a place on the vtxoa site that you can file a complaint with the NHTSA so they are aware of it. if you guys have an issue, file it too so that maybe some day, Honda may do something...
http://www-odi.nhtsa.dot.gov/ivoq/ <---- place to file your report
Can I get a an email, or link to this guy that swaps the flanges out? I searched on the user name and nothing came up.
Thanks
Ride Safe:choppersm
Discussion Starter · #8 ·
Thanks
Ride Safe:choppersm
he is on the VTXOA site. search there....
Discussion Starter · #10 ·
here is his email: [email protected]
he wanted me to let you guys know the following, and i quote:
"just remind them that I only have a few cores, I'm just a little guy not a big business
btw, for those who live around me, if you need to get this done, i can send you to the shop that i went to and he will fix the flange for you. now he is familiar with what needs to be done...
Discussion Starter · #11 ·
I am reviving this thread from the past because there have been a couple of people who have asked a link to bareass's website that shows the use of needle bearings (it in my post #1 above)...
· Slayer of Chickens
Great writeup footprinsinconc. Thread officially sticky.
Mort
VTX 1300c owner reare flange bearing question !
Hello everybody ,
just a quick question . Out of all the problems that people have had with this rear bearing has anyone contacted honda in CA to report the issue of the diameter being off so they can start a campaign to get a recall or a fix without us spending more money to have a machine shop bore the hole to the right spec ? I called honda today and they said they have had no complaints on this but i did get a complaint started so i would urge all who have this problem to call please . The number is (866) 784-1870 . This would go for 1300 and 1800's . Also have to comment about how to replace the bearing and reinstall very in depth great job !!! :mosh:
Hello everybody ,
They know of the problem and the dealers replaced 1000s upon 1000s of them.
They also know the bicycle bearing in the trees are crap and dangerous and didn't do anything to fix it.
Discussion Starter · #16 ·
Hello everybody ,
Thanks for the kind words....if you look at post #6, you will see that they know of this issue and have done nothing....
I have been reading through the forum in search of an answer to an odd sound my bike has started producing. At first the sound was very rare, but now it is becoming more frequent. It is difficult to describe, almost a vibration like sound-metal on metal... it does seem to be coming from the area of the rear tire. I came across this thread and wonder if perhaps this flange bearing issue might be the answer. No one has mentioned what the signs/symptoms of this flange bearing going out are. Can anyone describe what or how they became aware there was a problem with this flange bearing? I ride a 2006 VTX 1300 C.
· ~ High-Finesse Hooligan ~
For driven flange or wheel bearings, you need to simultaneously spin and feel the bearing turn with your index finger - it should be both smooth and silent - it should not feel 'like it has sand in it' (grainy), and certainly there should be no noise...
1 - 20 of 36 Posts
