I am replacing the seals/bushings/springs of my front forks. The problem I have run across is on the right fork. I can't get the fork socket bolt out. It goes in the very bottom of fork tube, and secures the fork dampener inside the fork tube. It is a 6mm hex head bolt. I think someone my have used red locktight on the threads. I re-installed the fork spring, to put pressure on the dampener, and hopefully keep the dampener from turning. No luck. I think the damper rod is spinning inside the tube, and the bolt won't come out. Anybody have any tricks on how to get the bolt out?? I tried air tools, and hand tools. I hope I don't have to try and drill out the bolt. HELP...:banghead:
