So I just got a 2003 VTX 1800C. The guy I bought it from said that progressive springs were installed in the front and I noticed it bottoms out and is very jarring when going over anything but the smallest of bumps. When resting, the forks are compressed to the point where there is only about 2 inches of travel space left before they would bottom out. When we took the cap off the forks, the fluid level was just below the threading for the cap. Trying to get this sorted out before any damage is caused by bottoming out, if we lift the front tire off the ground, they decompress about 4-5 inches. Thoughts? In a week, we plan to take them off, drain them, and take a look. Do we think these springs are shot and I should try to find a new set of springs before then?
· Super Moderator
There is probably no way to tell if the springs in the bike are the correct ones. Do they have any sort of identifying number on them? If so, perhaps you could use that to determine if they are correct. Is there any kind of spacer at the top of the spring? There is on a VTX1300. Is the length of this spacer correct? Each bike takes a specific length spacer so maybe this is wrong. Get the service manual and see what the fluid level is supposed to be. You can download the service manual for free here on the VTX Cafe.
Were the springs replaced correctly? The 1800 has one fork inverted. I'd bet it was installed incorrectly.
Reactions: mickeyrx70
2005 VTX1800 S2
Since the 1800 has inverted forks, it takes special tools to work on them. If you are unfamiliar I would recommend doing some looking around for tips and tricks. You will definitely need the special tools though.
Reactions: PaXman11
Replaced my 1800 seals and springs on my 2006 go to bareasschoppers.. 1300 forks are different, don't go with their suggestions
also check out the compression tool
I used these springs
There is something wrong there, I put progressive springs in my 2002 VTX1800C and got much better front tire wear, better suspension and better ride.
