1 - 10 of 10 Posts
revving at stop!
regarding the final drive gear oil plug-- the outer nut size is 17mm. honda was able to tell me the thread diameter is 14mm but could not tell me the thread pitch. i went to autozone and bought a bunch of oil plugs. the correct size is 14M 1.50 (cost $2.99 including washer)
when i tried to install the new plug with just fingers, i was not sure if i had the correct pitch size in hand because i could not turn the plug very much. i placed a small piece of paper in the hole and inserted my finger to get an imprint on the paper from the threads of the hole. i was able to see that 1.50 seemed to be the correct pitch. then i removed the oil fill cap and noticed its threads matched the 1.50 pitch. now somewhat confident i had the right size plug, i coated the threads of the plug with gear oil and used the 17mm wrench to tighten the plug.
the answer is 14mm plug with 1.50 pitch
(ISO metric screw threads are designated by the letter M followed by the major diameter of the thread in millimeters, e.g. "M8". If the thread does not use the normal "coarse pitch" (e.g., 1.25 mm in the case of M8), then the pitch in millimeters is also appended with a multiplication sign, e.g. "M8×1" if the screw thread has an outer diameter of 8 mm and advances by 1 mm per 360° rotation.
The nominal diameter of a metric screw is the outer diameter of the thread. The tapped hole (or nut) into which the screw fits, has an internal diameter which is the size of the screw minus the pitch of the thread. Thus, an M6 screw, which has a pitch of 1 mm, is made by threading a 6 mm shaft, and the nut or threaded hole is made by tapping threads in a 5 mm hole.)
thanks for the info!!! wa there something you needed help with? it says at the top of the thread you need some info urgently.
Good info, considering I snapped mine last night and leaving tomorrow morning for Nawlins and local dealer (largest in US) did not have one on the shelf! Should have used the torque wrench...:banghead:
Relocation Engineer
Good info,
My 17mm wrench and socket are not removing the final drive filler cap... I'm stripping the cap! Does anyone have any recommendations as to how to remove this F*ing thing?
Use only a 6 point socket or end wrench! they have the most contact area on the nut. I think thats a cast aluminum plug so its soft material.
1 - 10 of 10 Posts
