1 - 4 of 4 Posts
So when you install glens tool do you screw it all the way in and then back it out 2-2 1/2 turns or do you count the turns on the old one and then start from there
I do both, I count to see where the old one was just so I know where it was as a back up plan. Then I install the new one all the way in and bring it back out 2.5 as a starting point. The tune needed all depends on your set up and whats been changed on the carb & intake
PS, with the D tool that Glen sends along with the perm screw, it will be easier to count the turns if you use a sharpie and make a mark on it for a reference point. The perm tool also already has a notch in it for the same reason
1 - 4 of 4 Posts
