1 - 3 of 3 Posts
The problem with the neutral swich is in the crank case and is a cheap part.Wher is the fffn crank and does anyone have pics of this process.Thanks`
Pursuing Perfection
"neutral switch install, vtx 1300"
This was entered in the google search slot - up top just below Settings Tab -
The term can be altered in any way in search.
To Prove this works - Here's the results - Notice all results are from VTXCAFE w/o trying.
If you don't already have the Manual down loaded from this site - you'll be fighting the Process.
Have I ever done one? - No, but this is how to start - then get stuck - then come back with what it is.
I think most would question - why the switch is bad by explaining how it was tested.
Quite rare for them to go bad - so check wires.
About 412 results (0.33 seconds)
[COLOR=#CB020A !important]stupid clutch switch... - Honda VTX Forum[/COLOR]
So, when i picked up my '03 VTX 1300R a few weeks ago and promptly put 2000 miles on ... Install the neutral switch with a new sealing washer and tighten it.
http://www.vtxcafe.com/archive/index.php/t-2162.html
[COLOR=#CB020A !important]neutral indicator light - not coming on when it should[/COLOR]
When you order the neutral switch, on the parts finder diagrams, it is under CRANKCASE section. ... I did not replace the washer, (I forgot to order it), but the old one seemed .... By epiphysis in forum Honda VTX 1300 Forums.
http://www.vtxcafe.com/showthread.php/74304-neutral-indicator-light-not-coming-on-when-it-should
[COLOR=#CB020A !important]Neutral switch not working - Honda VTX Forum[/COLOR]
When I put it all back together the neutral switch was not working meaning I ... Honda VTX Motorcycle Forums > Honda VTX 1300Forums > Neutral switch not ... be a G/R (Green/Red) wire and a G/W (Green/White) wire for the clutch switch.
http://www.vtxcafe.com/archive/index.php/t-7971.html
[COLOR=#CB020A !important]Urgent Help neutral light [Archive] - Honda VTX forums for Honda ...[/COLOR]
Sep 16, 2012 ... I checked continuity of both kickstand and neutral switch and appears to be ... Honda VTX forums for Honda VTX 1300 / VTX 1800 motorcycles > The ... and probe neutral switch light green wire-light will light when shifted to
http://www.vtxcafe.com/archive/index.php/t-81400.html
[COLOR=#CB020A !important]Question No Neutral Light - Honda VTX Forum[/COLOR]
Bike in neutral, no light. Any thoughts of what to check first? Neutral switch? ... Honda VTX forums for Honda VTX 1300 / VTX 1800 motorcycles > The Honda ...
http://www.vtxcafe.com/archive/index.php/t-31362.html
[COLOR=#CB020A !important]Problem [Archive] - Honda VTX forums for Honda VTX 1300 / VTX ...[/COLOR]
if it has the original battery it may be time to get a replacement. .... Install a jumper from wire coming off starting relay that feeds clutch switch and diodes to ...
http://www.vtxcafe.com/archive/index.php/t-36957.html
[COLOR=#CB020A !important]Question kickstand safety switch - Honda VTX Forum[/COLOR]
Just got home on my '04 1300 retro. As usual, pulled into the ... Not alot in that circuit, in that same circuit is the Clutch switch. With the bike in gear, but the clutch ...
http://www.vtxcafe.com/archive/index.php/t-43151.html
[COLOR=#CB020A !important]Bike won't start [Archive] - Honda VTX forums for Honda VTX 1300 ...[/COLOR]
Bike is in neutral, kill switch ok. ... Is there somewhere that a wiring digram can be downloaded. ... this is for the 1800 but im sure that its the same for the 1300
http://www.vtxcafe.com/archive/index.php/t-13933.html
[COLOR=#CB020A !important]Question Clutch switch - Honda VTX Forum[/COLOR]
I tried removing the clutch switch to see if it can be adjusted but cant see it well enough to tell what is keeping it in place. If anyone knows how to remove this or ...
http://www.vtxcafe.com/archive/index.php/t-30431.html
[COLOR=#CB020A !important]Thread: Neutral switch not working - Honda VTX Forum[/COLOR]
When I put it all back together the neutral switch was not working meaning I cannot start the ... '05 VTX 1300C (Titanium) ... I believe there should be a G/R ( Green/Red) wire and a G/W (Green/White) wire for the clutch switch.
http://www.vtxcafe.com/showthread.php/7971-Neutral-switch-not-working
Pursuing Perfection
TO Answer -
Everything below the cylinders is the crankcase.
It Steers one away from the battery box - so the right Section of the Manual is related.
This word - "crankcase" as well can be searched - vs changing the words as they were found -
then making it more complicated than it is.
1 - 3 of 3 Posts
